6.0 keeps burning up starters
Old Aug 17, 2024 | 09:07 AM
mikebennett's Avatar
mikebennett
1st Gear
Hi I looked and could not find my issue. I have a 2003 ford f350 with the 6.0. I been through 4 starters since may. I have replaced starters and relay under dash key cylinder and ignition box in column. The problem I am having is sometimes you will turn the key to the accessory position and it will start cranking. Also some times going down the road it will put power to the starter and by the time I realize it the starter is burned up. Can go a month with no issues or the next day. I been pulling the relay after I start it but I forgot to today and lost another starter. Last one I put in was a bosh and I tried the 6.4 up grade. I would like to figure out my issue I know my issues don’t happen if I pull the relay I believe I have replaced everything before relay.
Old Aug 17, 2024 | 09:51 AM
Motohead911's Avatar
Motohead911
It sounds like an electrical issue. Given that sometimes it engages in the accessory position I would start be looking at the wiring in the column including the ignition switch.
Forgot, weird electrical issues have a tendency to be ground issues.
Old Aug 17, 2024 | 09:57 AM
Maxium4x4's Avatar
Maxium4x4
New one on me and you have electrical issues for sure, my 03 starter was replaced once since I have owned it. Had a cracked solenoid, not sold separately at the time.
Old Aug 21, 2024 | 09:00 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Do you have an alarm/remote start on the truck?
Old Aug 23, 2024 | 10:27 AM
joe blow's Avatar
joe blow
Hey guys I need help!
Help given
No return.
Wtf
Old Aug 26, 2024 | 07:09 PM
kbeefy's Avatar
kbeefy
If OP returns, or anyone else has a similar issue, check the Body control module (above the fusebox) for water intrusion and corrosion.
I had a customers truck (it was gas) that was eating starters and it was because it had a messed up BCM. If you unplug it and see green corrosion inside the plug, it's done.
Theres a writup around here (maybe in the Excursion forum) about taking them apart and cleaning them up. We just ordered a couple from a salvage yard and used the one that was in the best condition.
griffjf
Jul 16, 2024 12:21 PM
Dozerbeard
Jan 12, 2024 07:45 PM
Nick Sine
Jun 11, 2019 04:05 PM
dan6915
Jun 11, 2015 10:30 AM
RDC F250 7.3
Oct 27, 2008 09:36 PM
