Ford ft cobble??
Old Aug 14, 2024 | 09:48 AM
shaun.be's Avatar
shaun.be
Ford ft cobble??
Hello everyone,
I figured I'd ask here as someone if not most know way more about these engines than I do.'
I have a 1968 n700 with a 330 the exhaust manifolds were severely damaged, engine came out for exhaust work, still on the stand, I was able to pick up a running 391 but smokes out of valve cover similar to blow by but with no noticeable pressure.
My question is... can i put the 391 crank in the 330 block and use the same 330 rods and pistons?
From my reading the 330 has a 3.5 inch stroke and the 391 has a 3.79 in stroke and according to my math should make the 330 into a 357. We all know the ft engine has the piston way down in the hole from factory, so this will increase displacement as well as compression. Has anyone done this before?
I'm going to measure how far down in the hole the piston is now and see what I have to work with. Looks like I'll be up in the hole 0.145 inches at top dead center.
Old Aug 14, 2024 | 06:51 PM
shaun.be's Avatar
shaun.be
Nobody done this or thought about it?
Old Aug 14, 2024 | 08:37 PM
85e150's Avatar
85e150
Just freshed up the running 391.
It may mix and match or it may not. FT pistons are usually quite different from FE.
Taking a running 391 apart to make a mix and match 357 makes NO sense whatsoever.
Old Aug 14, 2024 | 09:13 PM
shaun.be's Avatar
shaun.be
Both engines are ft engines though. I'm trying to spend as little as possible on this, the 330 was rebuilt years ago but with low run time so I wouldn't pull pistons out of the cylinders, just new bearings and crank swap over.
Old Aug 14, 2024 | 09:15 PM
85e150's Avatar
85e150
Still a waste of time considering the 391 is a known runner.
Old Aug 14, 2024 | 09:34 PM
Destroked 450's Avatar
Destroked 450
That won’t work, simply swapping in the longer stroke crank will cause the pistons to extend past the top of the block
I don’t know of any FT engine combination using a 391 crank and 330 bore size
Old Aug 15, 2024 | 06:43 AM
shaun.be's Avatar
shaun.be
the 330 is a known runner as well.
Old Aug 15, 2024 | 06:46 AM
shaun.be's Avatar
shaun.be
I need to measure how far the piston is in the bore, i know its down in the hole pretty far. I am going to do that before I tear anything apart.
Old Aug 15, 2024 | 06:59 PM
shaun.be's Avatar
shaun.be
After mesuring, I'm at 0.165 in the hole with the 330. In theory I will have 0.020 worth of clearance after the crank swap. I'm going to give it a shot and see what happens, worst come to worst I will have to pull it back apart and try something else.
always fun to be different and try things just for the hell of it.
Thank for all the help.
Old Aug 15, 2024 | 08:00 PM
85e150's Avatar
85e150
Check your rod to bore clearance too.
And I would calculate the compression ratio based on that piston position as well.
Old Aug 16, 2024 | 11:18 AM
shaun.be's Avatar
shaun.be
That was the plan, I definitely don't want 10:1 compression
BigBlueBomb
17
Dec 12, 2013 03:40 PM
novadragman2005
Jan 6, 2006 12:57 PM
alk3myst
1978 - 1996 Big Bronco
Sep 2, 2003 02:57 PM
billp
Nov 15, 2002 10:25 PM
tomridge
Nov 15, 2001 05:23 PM
