Back-up Light Switch Question
Old Aug 13, 2024 | 02:22 PM
GeorgeAFTRLF's Avatar
GeorgeAFTRLF
5th Gear
Hi! I have a 1974 F100 3 speed truck I'm trying to get going.
I'm trying to figure out if my switch is bad or is something wired wrong.
I have a pretty simple question concerning the back-up light switch. Is it supposed to be complete the circuit when the plunger is depressed (reverse lever pushes it), or does pushing in the plunger supposed to break the circuit?
Right now my reverse lights are on when in neutral,1-3, but turn off when put I it in reverse. Seems like it should complete the circuit when the plunger closed. If the switch did the opposite of what it's doing, I would be fine.
Old Aug 13, 2024 | 04:32 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
I would say when it is pushed but from what you are saying it dose not work that way so I am not sure
Easy enough to check how many wires going to the switch?
Remove them. If 2 wires check if one had power with key on and are the lights on?
Then jump the wires together and check the lights, do they now come on?
If so you would want a normally open switch when in 1-3 and closed when in reverse.
If 1 wire it may ground that wire but check for power first before grounding.
If no power with key on and no lights ground the wire do you have lights?
If so just like above normally open in 1-3 and closed to ground when in reverse.
you can check the switch with a ohm meter.
See if it is a normally open (at rest) or normally closed (at rest)
It should change when you press it.
Dave ----
Old Aug 13, 2024 | 09:14 PM
tbear853's Avatar
tbear853
Is it a manual ... or ... automatic transmission?
If Automatic, the neutral safety switch and back up light switch are combined and mounted on top of the steering column well under the dash, Back up lights on in neutral, not reverse .... reads like the switch needs adjustment.
Old Aug 14, 2024 | 08:39 AM
GeorgeAFTRLF
5th Gear
Sorry - it's a manual.
Old Aug 14, 2024 | 08:48 AM
GeorgeAFTRLF
5th Gear
Thanks for the reply!
It is two wire. There is power when the key is in the on position. The button works OK, except it's doing the reverse of what I need.
When the truck is any gear besides reverse, the button on the switch is out and the lights are on.
When the truck is in reverse the shift rod pushes up on the button (as I believe it should) and then the lights go off.
Grounds at the lights lights are untampered with OEM and there is continuity. Everything else works.
Easiest solutions would be to get a switch that does the opposite of what it's doing right now, but I don't know if that's an option. Maybe the wrong switch is in there?
Old Aug 14, 2024 | 11:55 AM
FuzzFace2's Avatar
FuzzFace2
Got a picture of the switch?
Wonder if it is like a brake light switch and I know they come in different flavors, N. O. or N.C.
Dave ----
Old Aug 14, 2024 | 12:11 PM
GeorgeAFTRLF
5th Gear
Here’s a pic of the switch. Looks like it’s been there a while
Old Aug 15, 2024 | 09:18 AM
tbear853's Avatar
tbear853
Looking at the picture, it appears it could only be contacted by the 1-R lever coming out of the column in any event ... and since you only want the lights on in reverse when the lever is "up", it would follow that the switch needs closed circuit when depressed then. I looked the switch up on RA, looks like it's a generic pushbutton switch with just two screw terminals.
Reads like yours is busted up inside and a piece is fell out of place and shorting contacts when relaxed or "button out" .... and the piece is out of place when the button is pushed inwards? Such damage would be easy to have with age, heat, maybe adjusted too close or maybe fast shifts from N up to R?
Old Aug 16, 2024 | 05:10 PM
GeorgeAFTRLF
5th Gear
I was thinking that could be the case, but wanted someone else to confirm before I threw parts at it :-) It's definitely old!
warrant_ero
Feb 20, 2021 05:22 PM
Seanosu
Mar 11, 2016 07:42 AM
TexasTrash
27
Feb 9, 2015 04:52 PM
tjay460
Jul 2, 2005 09:04 AM
straightedge
Jun 6, 2004 07:41 AM
