Sponsored by: Real Truck
Squealing from 5 speed?
Old Nov 28, 2003 | 06:53 PM
mstepchinski's Avatar
mstepchinski
Question Squealing from 5 speed?
Hi -
I have a 1994 F-350 7.3 4x4, and am hearing a squeal when the clutch is engaged (normal position - foot off). As soon as I put any pressure ( even the slightest pressure - not enough to really disengage the clutch) on the clutch pedal, the noise stops. The squeal dosen't seen to vary in pitch when the engine rpm changes. Does anyone have any idea about this type of problem?
Thanks!!
Old Nov 28, 2003 | 08:15 PM
99f350sd's Avatar
99f350sd
Throwout bearing time.......possibly
Welcome to the site:
Old Nov 28, 2003 | 09:21 PM
FortyFords's Avatar
FortyFords
Its the throwout bearing as stated !
Rich
Old Nov 28, 2003 | 09:35 PM
mstepchinski
Is it going to hurt anything driving it like this? I have to have the transmission gone through to have the syncros redone, but really don't want to lay out the money for that yet.. I am double clutching now to try to put off the syncros..
Thanks again!
Old Nov 28, 2003 | 09:41 PM
FortyFords's Avatar
FortyFords
Tell us what makes you think you have bad syncro's?
You might just need the clutch and pressure plate and throwout bearings replaced.
if you let it go too long you may ruin the slide area that the bearing and the shift fork.
Rich
Old Nov 28, 2003 | 09:58 PM
mstepchinski
Well, if I don't double clutch between 2-3 and 3-4th, the gears grind, unless I let the engine run down below 1000 rpm. 1-2nd shifts are o.k., as well as 4th-5th..
jkschneider
Dec 14, 2009 12:42 PM
300-6cyl
1983 - 2012 Ranger & B-Series
Aug 16, 2006 12:24 AM
sa_rains
19
Dec 3, 2005 11:39 PM
RedStroker6
25
Oct 28, 2005 02:04 AM
mixer94
Jun 12, 2001 07:31 PM
