Need Help Diagnosing clutch
Old Aug 7, 2024 | 03:35 PM
Needinfo73_Ford_bread_truk's Avatar
3rd Gear
I have a NP 435 4 speed with granny low. I was deriving and heard a clunk and a couple miles after that I was stuck in 2nd gear. I tried starting the truck in gear and nothing. When i was started and put in reverse the truck would die. I put it in first gear and it started but would drive and couldn't change gears. I don't know what to do. Does anyone have any suggestions? Thank you
Old Aug 7, 2024 | 03:48 PM
tbear853's Avatar
tbear853
'Bout gonna have to pull the transmission out and have a look.
Old Aug 7, 2024 | 05:03 PM
Old Guy F-250's Avatar
Old Guy F-250
Welcome to FTE.
Hard to tell anything by your statement,
Few questions::
Does the engine start in neutral, if so how does it sound
How does the clutch feel,, strong as usual, or does it go to the floor easy
when in neutral, and the clutch is pushed in slowley, does it make any sounds or smoothe and quiet
Got more but this should get things started.
Old Aug 15, 2024 | 03:56 PM
3rd Gear
Thank you for your reply
Originally Posted by Old Guy F-250
Welcome to FTE.
Few questions::
ok so yes the engine starts in neutral. The engine sounds good except my timing is at TDC. I believe it suppose to be around six or so. When in neutral and the clutch is pushed in slow there’s a slight swooshines but it is quiet. The pedal has not had much firmness since I’ve owned. I was not able to start in a gear because the truck would die once in gear. The other day I put in 2nd and the truck started but was moving. I could not change the gear once rolling.
Old Aug 16, 2024 | 03:46 PM
Old Guy F-250
Well, one more question, when you say you were driving and heard a noise, was you pushing the clutch in or just driving down the road.
If you were just driving and heard the noise, well then re read tbear's idea. time to pull trans and see what happened.
If you were pushing the clutch in MAYBE something broke in the clutch linkage. If not, still time to tear it apart to see...Not being there it is impossible to tell, just passing on ideas......
I am not a mechanic nor did I sleep in a Holiday inn last nite these are just my .02 worth of ideas.. lol
Let us on here know what you find
Last edited by Old Guy F-250; Aug 16, 2024 at 03:48 PM. Reason: let us know what you find
Old Sep 1, 2024 | 04:47 PM
3rd Gear
I was able to roll truck onto level ground and get started while in gear. Once started i have to go and i cant shift into any other gear. i have to just turn truck off to stop
nighthawking
Aug 1, 2022 12:44 PM
Ryanhunt
Aug 31, 2020 01:07 PM
louand
39
Aug 23, 2016 01:31 AM
Alex Burdett
Mar 12, 2015 07:55 PM
Tyler E. Zimmerman
Nov 22, 2012 08:21 AM
