1980 F150 4x4. auto. Code number
Old Dec 23, 2010 | 05:09 PM
Ohydro91's Avatar
Ohydro91
Red face 1980 F150 4x4. auto. Code number
I got the code d3oe 9425 aa off the manifold, I can't find no other numbers besides the firing order, and I'm not sure what the engine is, does that code help? does any body know?
Old Dec 23, 2010 | 05:29 PM
dyingtolive's Avatar
dyingtolive
Check the VIN number on the door tag in the driver's side door jamb. Then take that VIN number and go here:
Ford Truck VIN Decoder 1973 - 1980
Being a 1980, you should be able to decode your VIN with that decoder. However, I suppose there's a chance that your VIN/sticker is different. If that's the case, go here:
Ford VIN Decoder - F150 F250 Pickup Trucks
To figure out everything else found on that sticker, like the transmission code, paint codes, etc., go here:
Vehicle Door Jamb Sticker Decoding Page
By the way, Welcome to FTE.
Old Dec 23, 2010 | 06:16 PM
Ohydro91's Avatar
Ohydro91
Thank you! Well The Engine is a different one then the original one. I typed it in one the computer and it came up as 73/74.
Old Dec 24, 2010 | 12:29 AM
Wyowanderer's Avatar
Wyowanderer
Your manifold engineering code tells a bit of the tale;
D3OE= 1973 (D=70 plus 3=73)
It's not foolproof, but helpful.
ctubutis's Avatar
ctubutis
A d3 prefix means a 1973 family of parts, some families are installed for 10 or more years.
IOW this doesn't tell you much about anything.
Pictures would be good.
Old Dec 24, 2010 | 02:05 AM
Ohydro91's Avatar
Ohydro91
I can post pictures tomorrow for sure.
Old Dec 24, 2010 | 11:47 AM
Ohydro91's Avatar
Ohydro91
https://post.craigslist.org/manage/2128246767/
There's a pic.
Old Dec 24, 2010 | 02:07 PM
ctubutis's Avatar
ctubutis
When I try to go to there, it tells me:
There appears to be a problem with this posting (2128246767) or the URL you're using to access it.
If you initially posted more than 48 hours ago, your post may have timed out, in which case you will need to repost your ad.
If you are clicking on the link in the email to reach this page, try using the cut-and-paste plain text URL instead.
If that doesn't work, please try again in 15 minutes. If it still doesn't work, please forward the email to help@craigslist.org for assistance
Thanks!
Old Dec 24, 2010 | 03:00 PM
Ohydro91's Avatar
Ohydro91
Thanks!
There this one should work.
1980 Lifted F150
Old Dec 24, 2010 | 03:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
D3 means it was originally engineered for the '73 model year.
O= Torino/Fairlane
E= Engine or powertrain part
9425 is the basic part # for all manifolds and clamps.
aa is an engineering revision.
These codes only reflect what the part was designed for, not what it was installed on.
For example, the famous D0VE heads were engineered for the 1970 model year, for the Lincoln division (V), they are an engine part (E)... but were also installed on both Fords and Mercury's and well beyond the 1970 model year.
Old Dec 24, 2010 | 03:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't know the nuances of 302/351 and can't see the interface of the intake and heads in that photo.
Old Dec 24, 2010 | 03:44 PM
ctubutis's Avatar
ctubutis
Yeah, I can't see, either.
If it's the engine that was installed at the factory in 1980 that's a 302, Ford
was using the M-blocks for the 351s at the time (which look a bit different
than the Windsors).
Franklin2 has a diagram that should help if somebody can get up close to the
engine:
Old Dec 26, 2010 | 10:43 PM
Ohydro91's Avatar
Ohydro91
than the Windsors).
engine:
I have a bunch of pictures here's a few more.
http://i269.photobucket.com/albums/j...myJanes018.jpg
http://i269.photobucket.com/albums/j...myJanes016.jpg
http://i269.photobucket.com/albums/j...myJanes015.jpg
http://i269.photobucket.com/albums/j...myJanes014.jpg
http://i269.photobucket.com/albums/j...myJanes013.jpg
http://i269.photobucket.com/albums/j...myJanes012.jpg
http://i269.photobucket.com/albums/j...myJanes011.jpg
http://i269.photobucket.com/albums/j...myJanes010.jpg
http://i269.photobucket.com/albums/j...myJanes009.jpg
http://i269.photobucket.com/albums/j...myJanes008.jpg
http://i269.photobucket.com/albums/j...myJanes007.jpg
Old Dec 27, 2010 | 07:21 PM
ctubutis's Avatar
ctubutis
From those pictures, it looks like a 351W.
What is the truck's VIN?
Old May 22, 2011 | 09:36 PM
4x484150's Avatar
4x484150
I have a '71 302 in my truck. This engine looks just like mine, so I believe its a 302.
BiltFordTuff
Jul 23, 2011 04:53 AM
mark060642000
1997 - 2003 F150
Jan 26, 2009 08:36 PM
amsvage
Oct 18, 2005 01:20 PM
Myckel
Oct 1, 2004 02:54 AM
