Sponsored by: Real Truck
Taillight issue
Old Aug 6, 2024 | 10:27 PM
2012 f2's Avatar
2012 f2
2nd Gear
Taillight issue
Help, recently got a 2012 f250 it had a utility bed on it with LED reverse and taillights. I removed the bed and went back with a factory bed, removed LEDs and went back with factory style taillights I got the reverse working properly but the issue I’m have is that turn signals work but don’t work when headlights are on (brake lights also don’t work with headlights on) and brake lights work but blinkers don’t when brake is pressed. Also wiring is butchered from previous owner cutting the harness at the main connector under the frame and made his own harness for the LEDs that were on it.
Old Aug 7, 2024 | 05:33 AM
projectSHO89's Avatar
projectSHO89
Your symptoms are of a "bad" or open ground for the rear lights. In factory form, it's labeled as G400 on the schematics. Rear left frame rail or cross-member. I'd suppose that the PO hacked up that part of the circuit and you'll have to restore it.
Black-white wire.
Old Aug 8, 2024 | 07:39 PM
2012 f2's Avatar
2012 f2
2nd Gear
Ok so fixed ground and now have blinkers working with brake light but still don’t have blinkers when headlights are turned on
Old Aug 9, 2024 | 06:27 AM
projectSHO89
Be more specific as to the malfunction, including possible variations. Rear turn signals only, front only, both front and rear or what? How about with the headlight switch in the park/running light position?
cosburn2005
Jun 21, 2024 05:51 AM
hoerunner
Dec 18, 2023 01:55 PM
crazy96863
Nov 29, 2023 03:16 PM
CameronBrule
Sep 14, 2018 10:44 PM
caelmalu
May 24, 2012 07:15 PM
