tailight harness
Old May 23, 2012 | 09:31 AM
caelmalu's Avatar
caelmalu
tailight harness
so i finally finished installing the spectra fuel tank. I got the bed back on, connected the wiring harnesses, only headlights and reverse lights work. (no turn or brake) the harnesses are really self explanatorry (so it would seem anyway) there's a 3 pin, a 4 pin, then a completely unique harness. It all worked when I took the bed off, no fuses blown. any suggestions?
Old May 23, 2012 | 10:55 AM
tecgod13's Avatar
tecgod13
Do the front turn and parking lights work?
Old May 23, 2012 | 11:09 AM
caelmalu's Avatar
caelmalu
front lights work fine, i just checked the wires again, the ground wire had me thinking there was another harness possibly folded back, but that's not the case. i sthere something to coat or lubricate those harnesses to ensure good contact?
Old May 23, 2012 | 02:51 PM
farmert's Avatar
farmert
If the 3 pin, and the 4 pin connectors are round, you have wiring for trailer tow package. The truck tail and brake harness that goes from truck frame to box lights should be a square plug.
Old May 24, 2012 | 07:15 PM
caelmalu's Avatar
caelmalu
turns out the tailight wiring harness can be plugged 180 degrees off if the locking tabs are broken off. problem solved.
Kelley D
Mar 31, 2017 07:22 PM
86'F-150
Jan 14, 2013 10:48 PM
EPDP99
Nov 6, 2005 04:33 AM
90bronco
1978 - 1996 Big Bronco
Mar 19, 2001 08:42 AM
