pump failure, fixed, still getting a code
Old Dec 7, 2024 | 08:08 AM
  #31
MeTo's Avatar
MeTo
A little update: I cleared the code and the permanent one with Forscan and did a relearn. The relearn I did was disconnect the battery
cables and then connect the passenger side neg to pos for a few minutes. That should discharge the caps. I drove the truck about 50
miles last Wednesday and Thursday with no error code. I pulled our camper across Arizona (~375 miles I10) yesterday with no code.
The truck runs fine. So? It will be interesting the next time I tow over a mountain pass?
If the code returns? My plan is to replace the pressure regulator valve with a motorcraft unit and carefully inspect the old one. My money
is on a questionable prv.
Logan ross
May 4, 2023 06:25 PM
Toork
Oct 7, 2021 06:36 AM
KHADIJE22
6.4L Power Stroke Diesel
Oct 23, 2011 08:40 AM
Texas450
Dec 17, 2010 10:52 AM
