Background/Build on my truck : https://www.ford-trucks.com/forums/1649210-97-long-and-slow-yacht-build.html
I recently removed my smog pump and ran a shorter belt. I am getting a KOER 311 thermactor code. Is there a way to bypass the electronics to eliminate this code?
thanks,
No, there is no way to bypass that error except put everything back. It will not trigger a Check Engine Light (CEL) so just ignore it when running the KOER tests.
OK. I have a check engine light but also have a 327 code. I was trying to eliminate issues, but if 311 doesn’t throw a CEL, that helps! Thanks.
