1990 F150 Custom (Australian)
5.8 EFI
2WD C6 auto
Single cab
G'day, was wondering if anyone could help me out. I noticed today my factory voltmeter started to drop while driving, at above 3000rpm. If I let off the throttle it climbs back up.
I had my son rev the car in neutral while I checked with a multimeter. Holding steady at 3000rpm the voltage at the battery dropped to about 12.3v. At idle, it is in the early 14v's. There was no load (lights, stereo etc) on when I checked.
It's an almost new battery, a good brand known for their quality over here in Oz. I've been running it with no issues for a few months.
The other suspect thing is while holding the revs high, the factory tacho jumps. This leads me to believe (and hope!) it's the dashboard voltage regulator and not the alternator.
My question is, should voltage drop that much at higher revs? Maybe I just haven't noticed before? Also, the "charge" light came on for a while at one point. (Aussie F150s have the older dash, from the '85 American models, I think.) Is that triggered by the voltmeter at the dash, or direct from the battery? I'm suspecting voltmeter.
The factory gauge is a voltmeter. The charge light is also kinda like a volt meter.
I've seen this behavior before in an alternator. The windings inside the alternator were broken, and as the alternator spun up, centrifugal force moved the windings apart and opened the circuit, stopping the alternator from charging.
Replace the alternator.
I would check the voltage at the battery. Then perform a voltage drop test at the alt to battery [positive post] and the alternator case to battery [ground post]. If that is ok, then start to perform voltage drop tests from the battery posts to the cluster.
I too have seen alternators fail at higher RPM's.
One other thing to think about. That battery is only used to start the engine. Once the engine is running, the alternator supplies the vehicle with power. The battery does not [yes, it can on certain circumstances]. If you focus your thinking on that, you will find the problem faster. Once the engine is running with a good alternator, you really don't need the battery.
Yeah i thought that was the case, which confused me as to why there was a slow voltage drop at the battery while maintaining higher revs. Although come to think of it, it dropped to 12.3v, which is around normal for a battery not being charged?
At any rate, when i bought the car there was a used alternator sitting on the floor, with Ford V8 written on it in paint pen. I'm now assuming PO bought it to change it over, and never did. I've had the truck for two years now though. But ill swap it in today and see what happens.
Thanks for your help guys, and your explanation Proto. Swapped in the JY alternator and she charges like a little champ now. Holds 14.6v steady at revs.
