230 amp alternator?
Old Jan 4, 2025 | 08:04 AM
  #121
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Will they work well for an EMP pulse device though?
Based on my DIY at home testing, yes...
That is all I can say about that here because of the three letter agencies keeping an eye on us for our own safety.
Old Jan 4, 2025 | 08:08 AM
  #122
FordTruckNoob's Avatar
FordTruckNoob
You and I need to talk. Face to face. At a secret bunker.
Old Jan 4, 2025 | 09:07 AM
  #123
kenn_chan's Avatar
kenn_chan
Talking
stay out of my head!
Old Jan 4, 2025 | 09:09 AM
  #124
kenn_chan's Avatar
kenn_chan
but seriously if you are running old school class A or AB amps you need a stiffening cap, if you a re running the current crop of class D's then you need bigger wires fuses and a battery that can dump and recharge as fast as a cap or close to it for the transients. this only really applies if you are really slamming like at 145db and higher though. if your below that it really does not matter that much unless you are really over driving a small amp..
Old Jan 4, 2025 | 10:48 AM
  #125
JoshHefnerX's Avatar
JoshHefnerX
I've been running the ss tarantula nanos for a number of years. Solid amps. 1 exception. The rca inputs. I've never had problems with this on any other amp, but have had them break. First time for me, so keep an eye on it. But they make Tiffany style RCA's for a reason...
That mdf is gonna double the weight of the box. Have you done the math on the size, the port is gonna take some space and the box is gonna be larger? Not much space back there.
Old Jan 4, 2025 | 10:51 AM
  #126
FordTruckNoob
Honeycomb carbon fiber panel for the subwoofer box win.
Old Jan 4, 2025 | 12:20 PM
  #127
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I remember visiting my uncle in 1971 when he was doing large cap testing in his apartment. He was soon and suddenly evicted.
Old Jan 4, 2025 | 01:02 PM
  #128
INFRNL's Avatar
INFRNL
I forgot about those power hungry pigs...his soundstream should be class AB iirc. I used to run a cap circa 90's-2000 on my ZX Phoenix golds (best amps I've run back then) I don't think they helped.
that was in my old 79...single battery, stock alt probably didn't help but it pounded for what it was. I didn't monitor voltage drop or anything back then
Old Jan 4, 2025 | 05:07 PM
  #129
RA101725's Avatar
RA101725
Banned
I bought a 50x2 Precision Power car amp to run a pair of mid/tweeter component speakers in 1999 and that thing was one nice piece of engineering. Wish I still had it as a coffee table conversation piece. Now I barely ever turn the radio on.
Old Jan 4, 2025 | 05:22 PM
  #130
JoshHefnerX
Pretty sure all of the nano amps are class D
Too small and not nearly enough heat sink surface on them.
Old Jan 4, 2025 | 05:43 PM
  #131
RA101725's Avatar
RA101725
Banned
Originally Posted by INFRNL
Soundstream used to make killer amps/ equipment.
Eclipse also. Those 8800 Series subwoofers with silver titanium cones were unreal. Too much for my budget.
Old Jan 4, 2025 | 07:33 PM
  #132
Hyakkimaru's Avatar
Hyakkimaru
I'm glad you decided to build a new box. Technically a high quality birch plywood is best, but the low grade MDF from local home improvement stores will suffice.
do not waste your money on caps, they do not work for your intended purpose/ reasoning. Exo did a video debunking them a while back and i can't remember what he said a person should actually use. I want to say a small lithium but that sounds slightly incorrect. I'll have to see if i can find the video.
what type of batteries do you run? and what size cable are you running to the sub amp?
I am capable of pushing 3000+ watts to my subs. I run 2 excellent quality AGM's along with oversized 1/0 (basically 2/0) to the amps. I do get some voltage drop but I think I stay above 13v even with my stock bosch alt. and that's ***** to the wall.
It's been a while but I will see if I can get a better idea for you tomorrow.
I only run 2 AGM, 1/0, stock alt. I did also upgrade all my factory power cables as well; I guess you could call it "The Big All" rather than the big 3
EDIT: I think I found it EXO cap vs ultracap
I think if you are dropping in to the 11's you have other issues and not supplying adequate/ stable power to the amps. It would have been nice if he also showed with no caps at all
Thanks for the video. I might send the capacitor back once it gets here. I agree that I would have rather him showed with no cap at all.
I've just got some AutoZone commercial batteries in there. I believe they were 850 CCA each or something like that. Alternator was put on the truck a few months before I bought it by my uncle who bought it local somewhere. Really want something else to put on.
Speaking of that parts truck, I am gonna rob the driveshaft out of it as my slip yoke is a bit wallered out. Only has 478,000 miles on it....
I have 2 Ga cable running back to a dual ANL fuse holder with digital volt readout splitter that splits to 4 Ga to both amps. TBH I haven't even thought about that wire. IIRC I was a little short for paper when I ran that wire and I believe my brother pulled it out of a pair of jumper cables. It is solid copper 2 Ga though, not the aluminum crap at least.
Had I known birch plywood was the best I would have bought that instead. When doing a quick google search for the best sub box material it popped up MDF and recommended 3/4 for 12's so that what I went off of. I didn't know ​​​​​​
Edit* I also have a volt meter phone charger in the 12v port in the dash that also drops to the same voltage as the voltmeter on the fused splitter. My fuel pressure also went down like 5 psi when the subs were beating hard. The voltmeter on the dash also drops when subs are beating in unison with the other two volt meters.
I do sort of now want some nice cable to rerun back there.
Old Jan 4, 2025 | 07:37 PM
  #133
Hyakkimaru's Avatar
Hyakkimaru
I used a website to figure the box airspace and it included the port to my specs and bracing in the airspace requirement and takes into account for the thickness of the material as well as the airspace the subs take up themselves.
These amps seem to be doing nice. I really like the lower bass of these 12's vs the 10's I had.
Old Jan 4, 2025 | 07:39 PM
  #134
Hyakkimaru's Avatar
Hyakkimaru
Hmmm. Sounds awesome. Also sounds expensive 💰💰
Old Jan 4, 2025 | 07:41 PM
  #135
Hyakkimaru's Avatar
Hyakkimaru
All of the Nano amps are indeed Class D amps.
