Adjusting Tire PSI
Old Aug 2, 2024 | 01:51 PM
cre8ivecowgirl's Avatar
cre8ivecowgirl
4wd High
Adjusting Tire PSI
We got a "new to us" 2019 Ford dually f-350 a couple months ago. We'll be towing our 4 Horse Elite Horse trailer with living quarters about half the time we use it (won't be adjusting tire pressure every trip).
This was an upgrade from a 2004 Ford dually f-350. I was expecting the ride to be a little smoother, considering the truck is a lot newer. But it's not! There's lot to like about this truck, but dang - the ride is rough.
I have read that running the tires a little lower than what's recommended on the sidewall will help make for a smoother ride?
Right now we're often hauling in the Texas heat.
I see some folks put more air in the rear tires?
Any suggestions?
Should we also run the horse trailer tires a little lower than suggested on the tire?
If so, as for the truck and trailer - how many pounds lower than what's recommended on the tire?
TIA!
Old Aug 7, 2024 | 05:36 PM
Beechkid's Avatar
Beechkid
IMHO, when carrying a load of that much weight, its not a good thing to mess with the tire pressures outside of the mfg specs..... while true, the ride will get a little softer for small incursions, without a load ok.....and it's best to measure the depth of tread across the tire face to get 100% even wear...that verifies you are at the correct pressure but, with a load, you are looking at spontaneous failure caused by underinflation.
Old Aug 10, 2024 | 12:13 AM
HRTKD's Avatar
HRTKD
The answer to these questions can be found in the tire inflation guide published by the manufacturer of your tires.
Old Aug 10, 2024 | 10:14 PM
Desert Don's Avatar
Desert Don
Any suggestions?
TIA!
I had one of these on a 38’ enclosed triple axle gooseneck trailer with torsion suspension behind a 16 F350 dually and it was a sweet ride.
I ran 75 PSI front and 65 PSI in the rears. Generally had between 3000 and 3500 pounds pin weight. Kept the tires on thetrailer at 85 PSI, which was max for the LR “E” if I remember correctly.
Good luck in your quest.
Edit: I can’t get the link to post. But, it was a “ Shocker Hitch” for a gooseneck trailer. If you google it, it should show up for you.
Old Aug 15, 2024 | 05:37 PM
wpg_250's Avatar
wpg_250
Trailer tires should be set to max psi(cold of course)when carrying a load and as a rule of thumb rear tow tires should be set to max when towing anything, but a lot of people adjust the psi depending on how much weight is on the back end so that decision is up to you.
My max psi is 80 and when towing my 6500# bumper pull I've run 70 front and 75 back and when unloaded it's 70 front/65 back and if I were to tow anything heavier than 6500lbs I'd set the rears to max 80 just to play it safe. If you want a better ride look into those silicon cab mounts and better quality shocks imho.
Bjaspud!
Aug 30, 2019 04:25 PM
Celtictexan
Jun 12, 2018 07:48 PM
jdadamsjr
6.7L Power Stroke Diesel
Apr 26, 2012 11:09 AM
Ford Fx4
2004 - 2008 F150
19
Feb 3, 2009 03:32 AM
bowhunter1331
Oct 31, 2007 09:40 AM
