69 E100 shift linkage for toploader
I've been playing with various projects on my E100 for a year or so (mostly just moving it back and forth across the street to avoid tickets.) I just resumed playing around with the shift linkage which I stopped playing with out of frustration a few months ago. I think I've finally got it all adjusted so it goes into and out of all the gears nicely, And this sounds so triivial but I can't find a clip that holds the rod to the trans selector successfully. The new bushings are really fat so I have to really squeeze to get any kind of clip in place and so far all of them (especially on the 2/3 lever for some reason) pop off. What kind of clips have worked for anyone that's done their bushings and adjustments? I've tried the type in the top photo, and I tried the type that came with the bushings that slide backwards into a narrower slot if you catch my drift. I'm thinking maybe the push nut type in the bottom picture? Any advice?
Scott
Look up the factory clips for a 69 Mustang or Camaro
Ford did use the same clips I have on My 68 Camaro now
The Camaro stuff is everywhere cheap
Maybe order those
That said, I have been stacking washers and using conventional Cotter pins for years
Those spring clips can pop off if you get gear pounding real hard
On my Boss 302, I have cotter pins and washers
Drilled another one the other dat on a brake pin for my 68 Camaro
I installed disc brakes and a booster
The pin had to be replaced and had a cheesy China clip
Now has a couple of washers and a cotter pin.
I figure it is safer, more robust
Might be a bit hard to remove your linkage pieces to drill them on a drill press
Cars are easy, your van column shift not so much, probably worth it anyway to rid yourself of some slop
