Odd Frame Attachment Whatizit
Old Jul 31, 2024 | 12:42 PM
682bear's Avatar
682bear
The truck is a 2017 F150 XL 4x4 5.0 Supercrew...
This morning, I removed the driver side front wheel to check the condition of the brake pads and rotor... I've been getting a little shimmy when stopping... and I noticed something (not brake related) that doesn't seem right to me...
Just behind the front wheel, there is a section of square tube welded to the frame, angled slightly toward the back. There is another piece of square tube bolted into the welded one that doesn't seem to serve a purpose. Nothing is attached to it... nothing is supported by it, it's just... there...
The really odd thing is, it appears that the end of this piece has been cut off with a hacksaw. It is not what I would expect a factory original piece to look like. There is an identical piece on the passenger side of the truck...
Is this supposed to be like this? Or did the previous owner do some 'high-quality-customizing' on this truck?
Thanks- Bear
Old Jul 31, 2024 | 01:48 PM
85e150's Avatar
85e150
"Crash bars". Added to bring the offset crash test results up to acceptable.
These are on my '17 2.7 4x4 SC. As they came from the factory. So yes, not a finished look.
Old Jul 31, 2024 | 01:52 PM
85e150's Avatar
85e150
Front side a little better but probably a rust trap in salt areas.
Old Jul 31, 2024 | 01:54 PM
85e150's Avatar
85e150
People cut them off to fit bigger tires but yours look original.
Old Jul 31, 2024 | 06:53 PM
682bear's Avatar
682bear
Ok, thanks for that...
I was just surprised at how the end was finished. I'm a machinist at work and fabricator at home, so the finish on the ends of those pieces look very amateur-ish to me. Yours are finished a lot better than mine.
-Bear
Old Jul 31, 2024 | 11:13 PM
JKBrad's Avatar
JKBrad
As others said, it’s a crash bar pit there by Ford to deflect impact force. There are 4, one each in front of and behind each front wheel.
Yours looks to have had the end taken off with something like a Sawzall. It’s commonly done to keep oversize tires from rubbing, especially with non factory wheels.
Old Jul 31, 2024 | 11:19 PM
85e150's Avatar
85e150
His end same as mine.
Old Jul 31, 2024 | 11:30 PM
JKBrad's Avatar
JKBrad
Now I need to go look at mine and see if the cut is that jagged.
Old Jul 31, 2024 | 11:39 PM
85e150's Avatar
85e150
Back ones are that way.
Old Aug 1, 2024 | 10:39 AM
GlueGuy's Avatar
GlueGuy
My step-son had a minor lift plus larger tired put on his 2020 long-bed super crew, and the shop chopped off the crash bars. We both looked at it, and it was our opinion that with the minor lift and only slightly larger tires that this was not necessary. He took it back to them and they welded them back on.
Old Aug 1, 2024 | 09:05 PM
JKBrad's Avatar
JKBrad
The cuts on the rear crash bars on mines are a little jagged, but they're straight.
bigcountry1009
All Things Towing
13
May 9, 2024 07:51 AM
bobj49f2
36
Jan 4, 2024 01:02 PM
mybloodisblue
1997 - 2003 F150
99
Sep 26, 2023 11:05 AM
JPMallory
Sep 30, 2019 03:30 AM
scott0531
Sep 14, 2009 02:24 AM
