New OTA update came through yesterday that added the compass direction to the dash for those who were upset that was missing from the factory in the ‘23s. Mine installed overnight and the compass is there now. It reset all my dash settings also in the process, but that was a simple enough fix before I went to work
Interesting - thanks for sharing. I'll be curious to see if/when this update comes through, as I was curious if they would push an update for the compass specifically since it was being added on people's vehicles which had the image processing module reprogramming recall completed. I have that recall listed on my truck currently, but have not wanted to bother dealing with the dealership or the potential headaches I've read on here from others (mileage being wrong afterwards, etc). I've not had any issues related to what this recall outlines, so I've just kind of avoided it for the time being.
I haven’t done any of the recalls either as I haven’t had any issues (knock on wood). No reason to fix what isn’t broken.
I think this is the first OTA update I have seen, or at least seen that came with a notification. Not sure how many there have been already for ‘23s but I have the 5G modem active since I bought it last year, so they should all be coming through without issue regardless.
Does the my view stick to the last screen you viewed after a restart?
It started at the bottom screen of my view instead of the main menu like it has before this update. I’ve only started it back up once since driving this morning. Will see what it does tomorrow morning.
Can confirm the dash also started on the same screen this morning as when I shut it off last night. So looks like the OTA update fixed that as well without having to get the dash screen recall done
Mine update on Thursday to version 6.3.0 Says it improved the back up camera quality.
I have not seen it do an over the air update in 6-7 months. Last I saw was 3.xx. So I was surprised to see it notifying me that it actually did an update.
But I did try the new feature to send a comment to Ford on what I'd like to see. ie Let the back up camera stay in the view I choose when I'm backing a trailer. Bugs the heck out of me, when I pull forward 3 feet to correct my back up and loose the camera setting.
