Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
The DODGE forum
Old Apr 14, 2004 | 07:03 PM
  #46
94matt's Avatar
94matt
Originally Posted by mr.salvage
I found a dodge diesel site last night, TURBO DIESEL REGISTER. and was suprised to find out the mighty cummins is not without faults. BLOWN HEAD GASKETS,SCORED PISTONS ON #6 CYL. BAD LIFT PUMPS, ETC.ETC.drive what ya like and be happy.
As a member of the TDR, I just wanted to point out that those problems are generally on highly modified engines.
Old Apr 15, 2004 | 05:20 PM
  #47
Saurian's Avatar
Saurian
Any high-volume production peice is going to have problems. The rarity is a peice that doesn't.
On these types of forums (Ford, Dodge, etc) you hear about the bad, not the good. You see 50 posts about the bad - but there are 5000 of us with good tranmissions that just don't sit and sing its praises all day.
E4OD is a good transmission. It has its faults, but it is a good transmission. Sturdy, reliable, and not too expensive to rebuild.
4L60 (700R4) is Chevy's transmission that somebody earlier was trying to talk about. They have a tendancy to fail. This is the fact that they are car transmissions thrown into anything from trucks with 350's...to Suburbans with twice the weight AND 350's.
The Dodge transmissions truely are crap. They're not as bad as the AXOD from the Taurus's..but bad. Not up to capacity...bad design, etc. I wouldn't own a Dodge unless it packed a manual - and even then it'd have to be New Venture, not DC.
Beyond that...change your fluid reguarly. Add either a new coil and fin transmission cooler in front of your radiator, or an inline frame-mounted radiator to your automatic as soon as you can. Only a few degrees can be enough to reduce the burnup of the friction modifiers that keep your transmission from scattering over the transmission pan.
satcomjimmy
18
Jun 18, 2016 06:54 AM
Its Broke
General Diesel Discussion
Dec 20, 2015 03:44 PM
Danbear
26
Mar 15, 2015 04:00 PM
sinister73
93
Feb 12, 2012 12:59 AM
IHbase
6.4L Power Stroke Diesel
Dec 20, 2009 01:49 PM
