Let's talk regen
Old Jul 24, 2024 | 07:16 AM
Hutch350's Avatar
Hutch350
Let's talk regen
Sorry if this has been covered but... I have a 2023 F350 6.7 XL. It has a little over 18K miles on it and I have never been aware of it performing a regen. The DEF usage seems normal and when I check the DPF % it looks good (goes up and down). I keep reading about folks using the Banks monitor to see the regen status or using Forscan (sp?) to enable a check box to control the auto-regen. My last big truck was a 2019 Cascadia and it was very obvious when it was performing a regen lol. What am I missing here with my F350? Hell, if it is taking care of business without me even noticing then that's great... right? Maybe since it's an XL with the simplified dash I might not be seeing something?
Old Jul 24, 2024 | 07:43 AM
SavageNFS's Avatar
SavageNFS
Unless you have an aftermarket gauge, the only way I know of to tell is the smell. Really tough to smell on the highway, unless you are following one in a regen.
Old Jul 24, 2024 | 08:30 AM
Flitastic's Avatar
Flitastic
I use the banks monitor to watch for active regens so I don’t stop in the middle of one . I have noticed that the dash percent in the DPF goes down very quickly but it stays active a good 15-20 minutes past that .
Old Jul 24, 2024 | 09:34 AM
Strider250's Avatar
Strider250
At 18K miles you have had, unless you are towing a lot, about 36 regens, it does it about every 500 miles. The 23 model year added a ninth injector located on the DPF which speeds up regens to about 10 minutes regardless of where or how fast you are driving. On my 23 XLT I occasionally look at the DPF% screen at around the expected regen time based upon mileage. The only time I notice a regen is if it occurs just prior to or when I shut the engine off and I smell burning from the exhaust. I do not have any extra gauges and even though I have Forscan I am not interested in messing with auto regens since the truck can take care of itself.
Old Jul 24, 2024 | 11:55 AM
WXboy's Avatar
WXboy
Did the addition of the "9th injector" do anything for fuel savings? Because on prior model years one way you could tell that you were in regen was that the instant MPG display would fall like a rock. Horrendous fuel economy while actively in regen.
Old Jul 24, 2024 | 03:27 PM
Strider250's Avatar
Strider250
Good question, I have not looked at that. I am due a regen in the next day or two and I will try to remember to look at that.
Old Jul 24, 2024 | 03:37 PM
acdii's Avatar
acdii
The newer trucks also have a passive regen that the older ones don't. Watching the instant economy will tell you when it is active as more fuel will be consumed. When doing a passive, it uses the extra heat from a hard pull to remove some soot, so watching EGT temps will clue on a passive. My 2019 wont do passive, at least not that I have seen, the % never drops but continues up until regen needed pops up. On the iDash I have seen soot percentage fluctuate, but only occasionally.
Old Jul 24, 2024 | 03:58 PM
senix's Avatar
senix
I could passively regen in my 2013 and in my current 2021. The issue really is EGT's.
Get EGT 11 and 14 up to around 700-800 F and it will passively regen over time. Up the hill you are up there burning fuel creating soot.
Down the hill the temps are hot and it passively regens all the way down the hill.
Old Jul 24, 2024 | 04:35 PM
4wd6.7L's Avatar
4wd6.7L
That right there is all you need to know that it is going into regen. I'd toy care,you could try to catch it while it's going down and continue to drive until it stops.
Old Jul 24, 2024 | 07:05 PM
Overkill2's Avatar
Overkill2
The older trucks will passively regen because I've seen my dash SL% reduce (in 5% increments) at least twice... does not happen often but have seen it. The Banks iDash SL% does drop when EGT4 is hot enough, usually at around at least 470ish to 500 degrees plus, and for the dash SL% to drop, the iDash SL% has to drop at least 10% IIRC... driving on a flat roadway you will not see it unless pulling a load but working the engine, like I do when driving the expressway home as altitude climbs and the hills I climb once off, it'll do it. But once it cools down, EGT4, SL% starts climbing again. I use Pittsburgh Power Max Mileage FBC so maybe it's helping...
Those latest and greatest with the 9th injector in the DPF get hot quick and get them done quick from what owners have been saying here...
Old Jul 24, 2024 | 07:08 PM
FishOnOne's Avatar
FishOnOne
From my understanding the "9th injector" regen process is more efficient. Still requires extra diesel to heat the DPF but requires less fuel to do it and you should still see it with the instant MPG display.
Old Jul 25, 2024 | 05:23 AM
Hutch350's Avatar
Hutch350
Thank you for all the replies. Good info. I figured it had to be doing regens but (in my opinion) I love the fact that I am unaware of when it does them. Like Strider250 said, "the truck can take care of itself". Take care all. - Hutch
Old Jul 25, 2024 | 10:41 AM
acdii's Avatar
acdii
I have only pulled heavy with it once down to Texas and back, only one decent grade the entire trip, so haven't really seen much in the way of high EGT to cause a passive regen, BUT, I also did not see a fast build up of soot either, more with towing than not, but not excessively. In daily driving I can go 700-800 miles or more between regens too. I no longer consider it a big deal, and my DEF use is VERY low. I filled it up 2 months ago, drove it often, and sitting at 100% still. Last time I only filled it up since I was there. I go about 1000 miles per gallon of DEF. It would take me a bit to figure out my towing DEF use since that was over a year ago, but I think it was roughly 200 MPG.
Old Jul 25, 2024 | 11:51 AM
Strider250's Avatar
Strider250
I just took the truck out on the turnpike this morning to check the regen mpg and here is what I saw. With the cruise control set at 65 mpg varied between 14 and 30+, there are hills here, during regen the mpg ranged between 10 and 20. When the regen stopped the mpg jumped from 14 to 20.
Old Jul 25, 2024 | 02:46 PM
rufushusky's Avatar
rufushusky
That is my understanding as well, in addition to not diluting your oil with fuel on the exhaust stroke, it is shorter and more efficient so there might be a nominal fuel economy improvement. How much, who knows. The 2020+ are already pretty good on fuel with the 10 speeds but every little bit helps.
