Put on a Gen Y hitch and going to take a test run. I can not see the ball (5" offset) with tonneau cover folded back or tilted up. I know about the telescoping ball etc...but is the camera tiltable?
No it is not, but you can zoom the view in. But that probably won't help if the line of sight is blocked. I can see my fifth wheel plate over my cross bed toolbox.
I have never used the Gen Y, so not sure if you have to see it all the way into home position. With my fiver, if I could see just the rearmost opening of the plate, so I knew I was lined up straight, I would not need to see it all the way in.
Have to add, the image from that camera is pretty bad. Far worse than the other cameras. Expected better.
