Cooling parts continued
Old Jul 22, 2024 | 07:40 PM
David7's Avatar
David7
4wd Low
I have a 1967 Ford F100 2 Wheel Dr. It has a 302 V8 power plant. It originally had the 3.9 L straight six. I am ordering a CC395 radiator from Champion radiators that they say will fit the truck. I need to get a fan shroud for the radiator, but they only sell fan shroud for electric fans. Can somebody tell me how to go about getting a fan shroud that will fit this truck for a 302. I would also need to get a fan and fan clutch as the truck currently has a direct drive performance fan on it with no clutch.
Old Jul 22, 2024 | 08:19 PM
silverflash's Avatar
silverflash
You might try National Parts Depot,,,,,
Old Jul 23, 2024 | 01:35 AM
RichS2659's Avatar
RichS2659
Here you go, second from the bottom, none super cooling size:
https://www.fordification.com/partnos/fanshroud.htm
from DC:
https://www.dennis-carpenter.com/tru...-os-fan-shroud
As it never had a fan clutch just go to your local auto parts store to get an aftermarket fan clutch and fan.
Old Jul 24, 2024 | 02:34 PM
FuzzFace2's Avatar
FuzzFace2
I got my 4.9 shroud for my 81 F100 from NPD.
As for a fan & clutch if you have one now why replace it?
Run it and see how it dose. Why spend more money if you dont have to right?
Mine should have a fan & clutch as I have AC and that is what the AC trucks had but all I had was a direct drive 4 blade fan and it works just fine.
Other then temp going up when I sit for a long time, AC on and 90*+ out, but once moving the temp comes right down to normal.
I think if I replace the 4 blade fan I would be better off I would not have this issue. Been this way for 5 years, 28k miles so far.
Dave ----
CropDusterMan
15
Apr 28, 2011 04:07 PM
460
Jun 24, 2007 02:06 AM
fling
Jun 2, 2005 09:47 AM
nikwave
20
Mar 2, 2004 07:17 PM
Big Hands
18
Apr 30, 2003 02:27 PM
