Sponsored by: Real Truck
Is this a good rear differential pattern
Old Jul 22, 2024 | 12:14 PM
Intel2you's Avatar
Intel2you
7th Gear
Just put in a new 5 cut gear set and all new bearings got 6 thou back lash. The pic's don't show it the best but pattern is about 1/8in from the root of the gear. Thanks guys
Old Jul 22, 2024 | 05:32 PM
DesertSmoker's Avatar
DesertSmoker
Yes that pattern will work. To make it perfect you just need a little more depth into the tooth but it looks good on left & right with a nice half moon shape. I would call it good to go just as it is. I would of love to heard that rear end when the pinion let go.
Old Jul 22, 2024 | 06:29 PM
Intel2you's Avatar
Intel2you
7th Gear
You know as well as i do you didnt really want to hear it by the time i got home you couldn't talk over it in the truck it had a vary vary slight noise only when slowing down at the start.seeing i had save 4yrs to buy a 22k truck. some moron rebuilt it the 3 day before I bought he had Receipts for the bearing from autozone I guessed it would need a little better adjustment boy was i wrong. the ride home was 1300mile and it started to wine a little over half way home then 200 mile from home it was grinding I did make it home but barely I later found they installed bearings for a newer rear I was able to move the pinion 3/8 inch in and out and when I took the rear apart they had took a grinder to the pinion because the pinion set back to far with the wrong bearing ridiculous what people will do to sell stuff I ended up rebuild the hole rear all wheel bearing, seals, e brake shoes, dust shields, new yukon gear set and all bearing and a crush sleeve eliminator and new clutches of course. I just wanted a 2nd opinion before I button it up. Thanks for the quick.
Old Jul 22, 2024 | 07:06 PM
DesertSmoker
Good job on getting the truck home under its own power. Good call on rebuilding the WHOLE rear end. Now you know its done right. Crush sleeve eliminator was a good call. I really dislike people/shops that do work that they know is bad/wrong and send it on its way. Hopefully the rest of the truck is way less eventful. .
1949Red
Jul 29, 2023 08:07 AM
Dave408
Apr 2, 2021 08:57 AM
grinnergetter
867
Apr 16, 2020 10:31 PM
James888
13
Feb 6, 2016 08:43 PM
