Excessive buildup intake valve
Old Jul 21, 2024 | 11:54 PM
mattios's Avatar
mattios
What could cause this kind of buildup I'm seeing for the intake valve? Any cause for concern as I refurbish? The other head they were all decent, as are the remaining 3 on this head.
Stock 302. Head/intake manifold gasket were intact. This is cylinder #4. The cylinder and piston look identical to the other 7.
Old Jul 22, 2024 | 12:53 AM
85e150's Avatar
85e150
Where does your PCV connect to the intake?
Old Jul 22, 2024 | 04:52 AM
charlie g's Avatar
charlie g
FTE Community Team
i'd be taking a good look at that cylinders valve guide wear,the bore, and rings, as what i see is a lot of OIL , always going to be carbon on the intake thanks to the cams valve overlap pushing un burnt gas back at the intake ,but thats way excessive
Old Jul 22, 2024 | 04:57 AM
Franklin2's Avatar
Franklin2
Looks like that engine sat around for a long time and that intake port got water in it.
Old Jul 22, 2024 | 12:32 PM
mattios's Avatar
mattios
It's actually right above this cylinder on the valve cover
I soaked it all down with some WD40 prior to taking the pic. It was bone dry prior when I took the valves out. Planning to clean it up later.
The engine did sit for about 25 years. Its ran as recent as a couple of months ago, but not very well.
Old Jul 22, 2024 | 03:07 PM
85e150's Avatar
85e150
PCV is on the valve cover, but where does the hose lead to? Where are the fumes entering the intake manifold?
Jtegg007
5.0L Coyote
Nov 9, 2024 03:17 PM
4x4k20
Modular V10 (6.8l)
Sep 1, 2021 11:48 AM
50trucking
17
Oct 1, 2020 07:50 PM
tomkat22
1983 - 2012 Ranger & B-Series
Nov 6, 2018 10:22 AM
Saigon
29
Jul 30, 2006 08:19 AM
