Sponsored by: Real Truck
Crank no start
Old Jul 21, 2024 | 08:56 PM
Gdub26753's Avatar
Gdub26753
2nd Gear
Crank no start
Soooo the dreaded crank no start
I changed pipes an dummy plugs and oil cooler.
put everything back together , added 2quarts of oil through oil filter housing. Cranked for an hour off an on while charging batteries an no start. Scangauge shows ficm sync, I also added the crank a cam but they stay at “0” while cranking ficm is “1”. 550psi oil , ipr goes to 84.7%. Fuel bowl fills and has 65psi at bowl , crank rpm’s are 170-185, ficm is 49v but logic volts drop down to 9v cranking ficm battery shows 12.4, batteries test at 13.3v. What am I missing to no start ? TIA you guys are awesome I always read the posts but this is my first one to make, 2006 f350 6.0 powerstroke
Old Jul 23, 2024 | 12:19 AM
Baylinerchuck's Avatar
Baylinerchuck
Not familiar enough with scan gauge to give any advice other than repost this on the 6.0 section of the forum. You’ll get a lot more traffic specific to this platform over there.
See ya over there.
STOFFERJ
Oct 30, 2023 01:56 PM
Visurveyor
Nov 9, 2021 06:50 PM
HardlyWorkin
Sep 4, 2021 11:46 AM
justisdaimpaler
Aug 31, 2021 09:12 PM
Brian Carter
Jan 26, 2016 10:20 PM
