overheats when pulling camper
Old Jul 19, 2024 | 09:18 AM
evanschiro's Avatar
evanschiro
4th Gear
1995 f250, 7.3 power stroke overheats when pulling my camper. I have replaced thermostat, flushed radiator, changed transmission fluid, and checked the fan clutch but still gets to hot pulling. Never even close when driving normal with no load. What can I check/suggestions ? Thanks
Old Jul 19, 2024 | 09:26 AM
farmert's Avatar
farmert
Does the fan sound like an airplane taking off when it engages? The fan clutch would be my first guess.
Old Jul 19, 2024 | 09:50 AM
z31freakify's Avatar
z31freakify
Is the condenser and radiator clear of debris on the fins? maybe it could be a radiator that is internally clogged, or you used the wrong thermostat, there's a long and short stem thermostat
Old Jul 22, 2024 | 07:51 AM
evanschiro's Avatar
evanschiro
4th Gear
Yes and it does not freely spin when its cold, or keep spinning when i turn off the engine.
Old Jul 22, 2024 | 07:54 AM
evanschiro's Avatar
evanschiro
4th Gear
Everything is clear on the radiator, the thermostat looked thee same as the one I replaced.
Old Jul 22, 2024 | 09:34 AM
knottyrope's Avatar
knottyrope
what is engine oil temp when it over heats?
your oil cooler could be clogged up and not cooling the oil enough
Old Jul 23, 2024 | 08:04 AM
evanschiro's Avatar
evanschiro
4th Gear
I'll check that.....Thanks
1999-F150
1997 - 2003 F150
Jul 1, 2018 10:00 AM
bart f-350
Mar 21, 2016 12:17 PM
Spkrvr
Sep 5, 2014 08:38 AM
l'il ol diesel
Jun 5, 2007 06:45 PM
Hamberger
Sep 14, 2006 07:30 PM
