Miss at light throttle
Old Jul 18, 2024 | 07:14 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
92 F150
5.0
Hello,
I'm trying to figure out why i have a miss at very light throttle while cruising. At least I'm assuming its a miss. Give it more throttle it goes away . It will also just die randomly while I'm cruising at low speed, Maby10mph or so. I cant make it die it just does it when it wants to.
I have changed tone of stuff,
Egr
Purge Solenoid
Throttle Body
Idle air control valve
Coolant temp Sensor
Intake air temp sensor.
Distributor
Coil
Fuel Pressure Regulator
Timing is at 10 deg
Tps
I sprayed carb cleaner everywhere looking for vacuum leak found none
Wires
Plugs
Map
I unpluged the Sprout and drove it it acts the same
Air filter is clean its a K&N if that matters
I took the filter out and drove it no change
Injectors
Brake booster check Valve
The Coffee Cans are not rotted
I had the compactors on the computer changed
Both of the tanks it seems to run the same.
I have 2 codes 542 and a 634. The 542 leads me to believe the pumps are bad but both of them. I don't know about that. I dont have a fuel pressure gauge or id check that.
Im stumped.
Thanks
Old Jul 19, 2024 | 02:58 AM
Prototypemech's Avatar
Prototypemech
First thing to do is get your hands on a fuel pressure gauge. Major auto parts stores loan them out for free with the correct adapters. Or you can buy a fuel pressure gauge kit on eBay/Amazon for a few dozen dollars.
Without knowing the condition of your fuel system, you're just gunna be throwing parts at the problem and hoping you get lucky.
Old Jul 19, 2024 | 06:58 AM
rla2005's Avatar
rla2005
Verify the firing order is correct and the plug wires are routed to reduce crossfire.
corrected image for 1993 and earlier 5L truck engines
https://www.supermotors.net/registry/media/72380
Old Jul 19, 2024 | 09:42 AM
McLeod's Avatar
McLeod
I have a 93 F150 w/ the 5 L.
Bought it new and from the day I bought it it has had a very slight miss/ shaky idle and goes away with just a slight increase in throttle.
With less than 30k miles I had changed the plugs/rotor/cap/wires, wire routing, resealing the intake, new injectors and iac, all at different times, hoping to find the culprit.
Fuel pressure within specs.
It did often die when stopping and changing gears like when backing out of a driveway into traffic. New iac solved that but the erratic idle remained.
While under warranty, Ford even had no idea what was causing it.
Now at 230k miles / 30 years later and with a new engine and computer with new caps installed and it still does that same thing.
I am quite certain that it is something in the electronics causing this.
Just one of those things that I chose to live with -vs- dumping tons of cash into with the hopes of fixing the minor issue.
Old Jul 19, 2024 | 12:37 PM
Soup bean's Avatar
Soup bean
When's the last time the fuel filter was changed?
Here's a thread on ground points. https://www.ford-trucks.com/forums/1...nd-points.html
The fuel pumps are grounded near the windshield washer bottle and the cable from the negative battery terminal, to the engine block and frame, can cause a lot of symptoms with these trucks.
Old Jul 19, 2024 | 04:58 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
Fuel pressure is 30 psi at idle and while driving.
Not sure when the fuel filter was changed had the truck a few months. When i looked at it it was shiny like it was new that's why i didn't change it.
Old Jul 19, 2024 | 07:55 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
I guess my firing order is 1,5,4,2,6,3,7,8. It wont run any other way. I even found tdc and re stabbed the distributor. Does this sound right?
Old Jul 20, 2024 | 07:40 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Unfortunately unleashing the parts cannon has made diagnosing the problem more difficult.
Although it was aimed at the distributor mounted ICM, wasn’t random stalling a sign at a failing ICM?
Old Jul 20, 2024 | 01:21 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
Thanks, i check it out.
Old Jul 20, 2024 | 02:11 PM
Prototypemech
Seems suspicious. It should raise to 35-40 while you're driving. Low fuel pressure will cause a lean-miss. What happens when you go full throttle on the freeway?
Old Jul 20, 2024 | 02:52 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
it dips slightly below 30 then goes back to 30. I tried both tanks, they are the same. So is this the fuel pressure regulator? There's no fuel in the vacuum line going to the regulator.
Thanks
Old Jul 21, 2024 | 12:18 AM
Prototypemech
What's the difference in pressure between key on/engine off, and key on/engine running?
Old Jul 21, 2024 | 12:29 AM
Conanski's Avatar
Conanski
Yes that is correct for your truck.
Fuel pressure should increase to about 40psi with vacuum removed from the regulator(engine idling), and it should never drop below the vacuum attached reading at any time.
Old Jul 21, 2024 | 07:29 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
30 psi engine off, 30 idle, if i rev it go to 35 then quickly back down to 30.
Old Jul 22, 2024 | 04:26 PM
Hynesgreg's Avatar
Hynesgreg
Trailering
Appears to be a egr issue. If I unplug the egr is runs great. Threw the light but run great now. So I need an egr?
