Harmonic balancer removal tips
Old Jul 18, 2024 | 04:42 PM
Stevenm95's Avatar
Stevenm95
I have to replace my harmonic balancer, I rented a tool to pull it from autozone and I heard to just leave the cone off and thread it directly into the crank shaft. I did that and it screwed up the threads. Chased the threads and got the bolt back in. What am I missing? Is something supposed to go in the crankshaft hole to stop it from Going in the threads and screwing them up? Can I just take the crank bolt out take off washer and press against bolt? Any help Is appreciated.
Old Jul 18, 2024 | 05:58 PM
97-psd's Avatar
97-psd
Usually, you can remove the washer, thread the bolt all the way in and press against the head of the bolt. Just make sure it clears the balancer as you remove it.
Old Jul 18, 2024 | 06:33 PM
Stevenm95's Avatar
Stevenm95
awesome ill give it a shot.
Old Jul 20, 2024 | 01:53 PM
Stevenm95's Avatar
Stevenm95
that worked got the new balancer and oil pump on. That method it came off like butter.
Old Jul 20, 2024 | 01:56 PM
96SD's Avatar
96SD
Did you use the Melling M208 pump?
Old Jul 20, 2024 | 03:48 PM
Stevenm95's Avatar
Stevenm95
yes I did.
96SD
Nov 8, 2022 09:19 AM
87oldtimer
Oct 12, 2019 07:58 PM
quakerj
Aug 21, 2013 07:08 PM
my93
Dec 31, 2011 10:29 PM
mattrlang1
Nov 12, 2002 08:30 AM
