Has anyone found a place that will make the California CVRA stickers into magnets so you can pull them off when not towing? Any insight would he appreciated!
I don’t know what CVRA stickers are but if they are just common stickers you can buy sheets of magnetic mat online fairly cheap and then just stick the sticker to the mat then trim around the sticker, you would then have removable magnetic stickers.
Thanks! For some reason I wasn't thinking of the obvious. The CVRA is a weight sticker you have to run on commercial vehicles. Appreciate your response.
Since it's a brand new Dually and also for personal use, I want to just run them when I am towing. I see Dually's everyday in LA not running them so I should be fine. I can walk into 3 different CHP offices and get 3 different answers.
