Powerless
Old Jul 17, 2024 | 05:02 PM
outinit's Avatar
outinit
Trailering
Powerless
Picked up a 2000 f350 at auction...485k miles. Started pretty easily on a cool morning after sitting for 2 weeks. Drove it 150 miles home. Had no power for hills, luckily they were big mild grades, dropped down to 35mph at the top of a few, besides being a traffic nuisance it did made it ok otherewise. Temp stayed relatively steady. No unusual smoke. I know zilch about it...top places to look into to adrss the power issue? Thanks.
Old Jul 17, 2024 | 05:15 PM
Walleye Hunter's Avatar
Walleye Hunter
If it's not smoking, I'd look at fuel filter and fuel pressure, filter is easiest and pressure is next. With the filter cap off, you can check fuel flow into the bowl, which will tell you something about your feed line and pump. Then you can figure out where to head from there. There is a port on the back of the fuel bowl where you can attach a fuel pressure gauge. I do not remember what size that hole is though.
Old Jul 17, 2024 | 07:54 PM
z31freakify's Avatar
z31freakify
Check the MAP sensor hose, could be torn not allowing it to boost up and not allow fuel to be dumped when needed.
Old Jul 27, 2024 | 10:35 PM
outinit's Avatar
outinit
Trailering
Just wanted to say thanks for the REs...havent had time to get under the hood yet. Will update with progress/solution as I can.
Old Jul 30, 2024 | 12:18 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I always recommend a dedicated fuel pressure gauge. Most boring thing in the world but when the truck acts up it cuts diagnosis in half.
Jose Alamo
Oct 4, 2021 05:07 AM
rrjfy
Mar 20, 2019 04:00 PM
kyeatman74
Jun 3, 2012 06:55 PM
jack_pine
Feb 27, 2010 07:07 PM
08350
6.4L Power Stroke Diesel
Jun 29, 2007 05:37 PM
