I have a 2021 F350 Lariat with the same issue. No success in finding the problem. However I did discover it works early in the morning while it's still fresh outside and once it warms up it no longer functions. I've checked and double checked all possible connections and nothing yet. Thinking it might be a defective module somewhere.
Not sure, but that’s the way it sounds. Local Ford service dept has had some turnover and it appears they are training people still, not very good at relaying information. I’ll let you know after it is finished up what all they did.
I've been to 2 different Ford dealers under warranty to fix this issue on my 2022. Neither dealer fixed the issue. Sometimes it works but most of the time it doesn't. Since the second dealer replaced my camera I think they reprogrammed something because when the camera does work I can't toggle between any other views.
I got mine replaced yesterday under warranty. It appears to be working for now. My issue was, I could not even get an image on it. I could select all my other camera views, but as soon as I tried the bed camera, it would lock up the other views and could not see any of them.
