Sponsored by: Real Truck
No start when hot
Old Jul 16, 2024 | 01:41 AM
Ford's only las vegas's Avatar
4wd Low
No start when hot
Hello i have my 2006 f350 with the 6.0 heres the thing the heads have been bullet proffed before I got the truck ok now i had the stem pipes replaced but i was told they were new i also replaced the ipr valve and the sensor in the value cover on the right side im still having the issue that when it gets hot it won't start unless i let it cool down o have no warning lights on nothing please i need help
Old Jul 16, 2024 | 11:42 PM
Baylinerchuck's Avatar
Baylinerchuck
Weren’t you already on the 6.0 section asking about this? Seems I’ve seen this post before. Sounds like a high pressure oil leak. Get FORScan or a likable facsimile so you can diagnose the issue or load up the parts cannon and start spraying randomly.
Old Jul 17, 2024 | 01:29 AM
4wd Low
No start when hot
Yeah ive already changed and bullet proffed the heads replaced the stand pipes changed the ipr valve i have noticed that when starting the engine oil pressure gauge doesn't move until it starts i don't know what to do i just want it fixed is all
Old Jul 17, 2024 | 06:07 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If you haven't been to the 6.0 forum, head there. If they're not able to help you out, then it needs to go to a GOOD diesel shop.
Old Jul 17, 2024 | 07:24 AM
Baylinerchuck
You need a good scan tool like FORScan so you can monitor the ICP and IPR otherwise it’s a shot in the dark. Go watch Diesel Tech Ron videos on YouTube and you’ll see what I mean.
Tate_B
May 15, 2023 07:58 AM
Skraztastik
Mar 3, 2015 10:28 AM
Olpowerstroker
Jan 9, 2014 06:36 AM
DieselOwnerNow
Dec 9, 2013 05:57 PM
Olpowerstroker
Oct 6, 2013 08:25 PM
