Spring pad width
Old Nov 27, 2003 | 08:40 PM
willowbilly3's Avatar
willowbilly3
Spring pad width
I found a 3.54 dana 60 in a 75 at the junkyard and I got to thinking it might make my 240 a bit more drivable than the 4.10 it now has. Does anyone know if the spring pad widths are the same on the 67-72s and the 73-39s? I know the frames are wider.
This could be a poor man's version of overdrive; 3.54 gears with some 33 inch tall tires. Then stick a manual tranny like a T-18 or maybe a 3 speed behind my C/4. A friend of mine did this with a chevy. He had a 454 turbo 400 in a dually that he drug these humongous loads around with and it had a muncie pickup 4 speed behind the turbo 400. We had a local guy with a driveline shop and I think he got the connecting shaft made for under $100.
So anyway you could use second or third for around town and on the jobsite or towing and shift the manual into high when you got up to highway speed.
Old Nov 28, 2003 | 11:19 AM
tex1264's Avatar
tex1264
i'm going to change out a 76 model rearend in about a hour i'll measure it for you. i'll post it a little later this afternoon kevin
Old Nov 28, 2003 | 01:57 PM
tex1264's Avatar
tex1264
i just got done changing out a rearend in a 76 from center of spring pad to center of spring pad it is 44&1/2 inches kevin
Old Nov 28, 2003 | 02:13 PM
willowbilly3
Thanks tex. I will measure my 68 when I get back outside
speedfreak78
20
Jan 24, 2023 07:36 AM
KsHighboy
13
Aug 28, 2016 04:11 PM
The Freak
May 14, 2015 08:56 AM
axe_handle
17
Sep 28, 2009 04:02 PM
Charles-65F350
Mar 14, 2001 08:20 AM
