Sponsored by: Real Truck
Finding a short
Old Jul 8, 2024 | 07:10 AM
Digital Dummy's Avatar
Digital Dummy
6th Gear
Finding a short
I have a 99 F550 7.3 that seems to have a short somewhere.
I have burned up 4 alternators since last year.
Are there some common issues of shorting out somewhere that would be the first steps.
I'm not an electrical wizard, and the 2 different mechanics I have taken truck to just keep replacing alternator, as it seems to fix the issue for a few weeks.
Any help would be appreciated.
thanks
DD
Old Jul 8, 2024 | 08:58 AM
apache84's Avatar
apache84
Are the alts just crapping out and no longer charging? Have the mechs checked the alts output when running?
Old Jul 8, 2024 | 09:10 AM
Digital Dummy
6th Gear
The old one i just took out was about 12.2v. 2 months ago it was 14 plus when I put it in.
New one goes as high as 14.5 at 2000rpm
but it seems to slowly lose output in 1 hour drive. dash display went down to zero, and then truck quit.
I load tested batteries for the heck of it, they are about 1 1/2 years old. both check out fine.
But it does drain battery power to zero when alternator stops functioning properly.
Old Jul 8, 2024 | 09:56 AM
apache84's Avatar
apache84
Im not sure off the top of my head how much juice a 7.3 needs to keep going. For example the alt in my 99 V10 died a few weeks ago, but I made it some 3 hours home on battery only. A good fully charged battery will sit at 12.6ish when parked. Running you will see 13.8 to 14.3 at idle or some more rpm. Id think what might seem like a good short would smoke some wires or at least put such a load on the alt it would be screaming for mercy. I hate to say it but there is so much junk out there as far as parts these days Id not discount that as well. If you had a good fully charged battery, had it idling with the hood open to let some heat out does the alt or battery cables get really hot? Is it possible you have a hung glow plug/intake heater relay?
Old Jul 8, 2024 | 10:02 AM
Eman85's Avatar
Eman85
Define short.
It sounds like the common poor quality auto parts we are now faced with. If possible I always opted for a good rebuilder to install quality parts in a factory alternator or starter. Unfortunately most rebuilders have gone away as they can't compete with cheapo new replacement alt and starters from the auto parts supermarkets so here we are. Battery condition and condition of all connections would have the biggest effect on an alternator.
Old Jul 8, 2024 | 12:59 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Give this a try.
May help... May not help.
File Type: pdf
Old Jul 8, 2024 | 02:25 PM
Digital Dummy
6th Gear
Finding a short
Originally Posted by Jimmy's Pilot Service
Give this a try.
Thanks for the info.
A lot of useful stuff, but once I see it on paper it seems to make more sense (sorry, ADHD).
dd
Old Jul 8, 2024 | 07:04 PM
bajaphile's Avatar
bajaphile
Most all the circuits should be fused. A short will pop the fuse and not create an electrical fire.
A short that would kill an alternator would need to be massive (guessing 70ish amps). That amount of current would burn up most wires on the vehicle, except for maybe the battery and starter leads. I'd probably check all large gauge wires for any burning, cracking or chafing.
Most likely cause is cheap replacement alternators... Do you know what type alternators are being used? Do you have any large non OEM equipment that would be pulling large loads?
Old Jul 12, 2024 | 02:50 PM
Digital Dummy
6th Gear
HI.
Lol, this is about as basic a truck as it comes, other than power windows.
The ford dealer in my area doesn't even have the actual motorcraft one and I was in a hurry, again.
I am not sure of the brand but it definately is an aftermarket alternator.
I will check all the main wires this weekend.
thank you
DD
BB1212
Jul 3, 2021 08:22 AM
wwracer
Mar 13, 2021 10:44 AM
Justins 7.3
Feb 13, 2014 01:19 PM
31vikes
Jun 9, 2010 10:54 AM
teammaxdale
Mar 14, 2007 03:50 PM
