Sponsored by: Real Truck
Transmission Problem Help
Old Jul 7, 2024 | 11:17 PM
Robert77's Avatar
Robert77
4wd Low
I have a 99 F250 Super Duty 7.3, I put in a transmission from a 2002 F250 Super Duty. I have 1st and 2nd gear but no 3rd or overdrive. Do I need to get a solenoid pack for a 99 to put into the 02 transmission?
Old Jul 8, 2024 | 04:36 AM
Old and soft's Avatar
Old and soft
Maybe this will help.
https://www.ford-trucks.com/forums/1...atibility.html
Old Jul 8, 2024 | 08:57 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The shift solenoids are identical between 99 and 02. Solenoid body compatibility is not your problem.
What codes are stored in the PCM?
Old Jul 8, 2024 | 01:18 PM
Robert77's Avatar
Robert77
4wd Low
They were 0705,0603,0708,0500 but I cleared them took it for a ride and now just 0708
Old Jul 8, 2024 | 09:13 PM
Mark Kovalsky
You have either a bad TRS (Transmission Range Sensor, located where the shift cable attaches to the trans) or damaged wires to the TRS. Fix this, and the problems you're having will probably disappear.
Old Jul 9, 2024 | 01:47 PM
Robert77's Avatar
Robert77
4wd Low
Boy I feel dumb I've been trying to figure out were the TPS was at.I thought that was the nuetral saftey switch..I did buy aì repair pig tail for the Tps because every wire to it was bare at the plug . I really appreciate your help this has defiantly been a learning experience.
Old Jul 9, 2024 | 01:49 PM
Robert77's Avatar
Robert77
4wd Low
I'm going to go buy a new Tps and a new shifting cable . I will let you know if it fixes my problem
Old Jul 9, 2024 | 02:28 PM
Mark Kovalsky
TPS (throttle position sensor) is located on the accelerator pedal on your truck.
Old Jul 9, 2024 | 08:58 PM
Robert77's Avatar
Robert77
4wd Low
Sorry that was suppose to read TRS
Old Jul 9, 2024 | 09:36 PM
Mark Kovalsky
The TRS is also the neutral safety switch.
Old Jul 10, 2024 | 09:22 AM
Robert77's Avatar
Robert77
4wd Low
OK I put in the new TRS / NUETRAL SAFTEY SWITCH I HAVE NO MORE COEDS BUT I STILL DONT HAVE ANY 3RD OR OVER DRIVE
Old Jul 10, 2024 | 09:58 AM
Robert77's Avatar
Robert77
4wd Low
The tranny I took out of my truck had a PTO and the one I put in don't . Could this be the problem?
Old Jul 10, 2024 | 01:56 PM
Mark Kovalsky
No, that's not the problem.
Can your scanner read data? Can you tell if the PCM is commanding 3rd gear or not? That will help determine if the problem is inside or outside of the transmission.
Old Jul 11, 2024 | 04:24 AM
Robert77's Avatar
Robert77
4wd Low
Xxxxxxxxxc
Last edited by Robert77; Jul 11, 2024 at 04:55 AM. Reason: It was posted twice so I erased this one
Old Jul 11, 2024 | 04:52 AM
Robert77's Avatar
Robert77
4wd Low
DIGITAL transmission range switch 1 closed, switch 2 and 3 are closed. DIGITAL TRANSMISSION range switch 3(v) 0.010v. Switch 4 n/a. Shift solenoid #1 and 2 Electrical fault no error. Shift solenoid1 on, Shift solenoid 2 off,Speed control command switch(v) 6.579v.
I don't know what any of this means or if this is what your talking about
