Trans cooler
Old Jul 6, 2024 | 12:46 PM
Hmcfly626's Avatar
Hmcfly626
Trans cooler
I don't know if this has been talked about before I read were the 2017 f250 6.7 trans can run up to 250 degrees hot I had a time I was towing my 9000 pound trailer up a hill and my dash lit up so I pulled it over to let it cool down I've read where people say you don't need a trans cooler because it really doesn't help the temp go don't that much anyway but themn in my research I have found the opposite were they are saying it will help the temp go down I have a mishimoto trains cooler sitting in my office and I haven't decided should I install it or send it back to Amazon I keep flipping on it I'm towing 9000 through a hundred degree temp desert for a 3500 trip I need input thanks or should I just save my money and don't tow over 65
Old Jul 6, 2024 | 12:58 PM
nc350's Avatar
nc350
I think you'll get a consistent response that you won't need it.
Old Jul 6, 2024 | 02:29 PM
Desert Don's Avatar
Desert Don
AFAIK, trans is cooled by seconary cooling system, (oil to coolant), so if it is actually overheating, it might be more wise to have secondary cooling checked for actual temps and operation before putting a bandaid (Mishimoto. ) on it!
Old Jul 6, 2024 | 04:04 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You seem to have a resistance ro punctuation and sentence structure...
Towing uphill and the dash lit up, lit up how???
Why do you think it was the trans temp causing it?
Trans cooling is thermostatically controlled, so an aux cooler may not help much.
And, the trans is designed to run fairly hot anyway.
Old Jul 6, 2024 | 05:04 PM
OBS460's Avatar
OBS460
If your trans hit 250F while towing a 9k lb boat there is a totally different issue that needs addressed rather than installing a secondary cooler.
Old Jul 6, 2024 | 05:08 PM
Rwhjr's Avatar
Rwhjr
Right on brother correct that punctuation……hit him with the knowledge
Old Jul 6, 2024 | 09:50 PM
WK15's Avatar
WK15
Old Jul 6, 2024 | 10:14 PM
Wyldfire's Avatar
Wyldfire
250 transmission temp didn't light up your dash. That is well in it's acceptable limits. Truck makes no real attempt to cool it till 260's then the fan will ramp up and cool it fast. Watch this long video that shows how the truck is programmed by Ford and what temps your transmission wants:
Old Jul 7, 2024 | 07:10 AM
senix's Avatar
senix
my guess is unless there was a mechanical issue, these temps were never seen.
Garberinc250
Jul 12, 2018 12:34 PM
grec-o-face
37
Apr 10, 2012 06:50 PM
svt2205
2004 - 2008 F150
Jan 12, 2011 07:16 PM
cfaix
Sep 23, 2009 11:41 AM
krzyk26
Apr 4, 2006 07:59 PM
