Trans temp/ factory cooler
Old Jul 11, 2018 | 08:04 PM
Garberinc250's Avatar
Garberinc250
Guys... I have a 2018 F250 6.2 gas. 1700 Miles on it.
Unloaded, trans temp runs between 180-203.
Pulling our 7200 pound TT, temp settles in around 200-207
I realize all these temps are normal, but with the trans oil cooler installed, shouldn't these temps be lower?
My 2016 F150 ran the same temp without a cooler pulling the same trailer.
Thanks guys.... Sorry if a dumb question. Never had a trans cooler before.
Old Jul 11, 2018 | 08:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, they shouldn't be lower. There is a thermostat that keeps the transmission at those temperatures. The transmission is more efficient at higher temperatures. With higher efficiency, the truck gets better fuel economy, and fuel economy is king now.
Yes, you've had a trans cooler before. All automatic transmissions have transmission coolers.
Old Jul 11, 2018 | 08:54 PM
crewzer's Avatar
crewzer
The old post may be informative:
https://www.ford-trucks.com/forums/1...l#post17499954
HTH,
Jim / crewzer
Old Jul 11, 2018 | 09:07 PM
Garberinc250
Mind.... Blown.
So do cars and light trucks have in the tank coolers? Or so they have the small mini- radiators as well?
Man, what a nube! Thanks for all the info guys
Old Jul 11, 2018 | 09:13 PM
Mark Kovalsky
Some have in tank coolers, some have small mini radiators as well, and some have only a separate mini radiator. It varies.
Old Jul 11, 2018 | 09:17 PM
Garberinc250
Mark.... Thanks for all your info. I did read through that thread you posted . So it appears the radiator I am seeing in front, toward the top is the power steering fluid cooler.
Where then is the trans cooler on the 250?
And then, some folks add another (auxillary) trans cooler to their vehicles. This is an addition, obviously to the stock cooler, correct?
Old Jul 12, 2018 | 06:05 AM
rfbrain's Avatar
rfbrain
The Radiator, Condenser(AC) and Trans Cooler are configured in a pack with the Condenser and the Trans Cooler mounted directly in front of the Radiator. The Condenser (larger) is on bottom with the Trans Cooler (smaller) mounted above it. The power steering cooler is mounted out front of the Trans Cooler and can be seen directly below the Hood Latch assembly.
The Trans Cooler has 2 hose lines that go into the Passenger side tank of the radiator.
Old Jul 12, 2018 | 12:34 PM
Mark Kovalsky
Yes, they do. One needs to be careful because too many coolers can cause too much restriction, which can reduce transmission cooling.
parcours
2009 - 2014 F150
Dec 6, 2015 11:44 AM
norfolknova
18
Aug 8, 2012 12:32 PM
svt2205
2004 - 2008 F150
Jan 12, 2011 07:16 PM
cfaix
Sep 23, 2009 11:41 AM
krzyk26
Apr 4, 2006 07:59 PM
