Reverse lights always on
Old Jul 2, 2024 | 02:03 PM
BigBair's Avatar
BigBair
I have a 2019 F250 and replaced my reverse lights with LED bulbs - they are a HUGE improvement over stock. I recently noticed the reverse lights stay on all the time. The constant on is significantly less bright than in reverse, but they are constantly on.
I am not sure if this is due to the LED bulbs being more sensitive to small amounts of voltage, or an issue with power somehow back feeding to the reverse lights, or possibly a combination. I have paid attention to other similar year trucks on the highway (2017-2019) and noticed that several appear to have the reverse lights on while driving - most of which appear to have OEM reverse lights. I do not recall noticing this on the 2020+ trucks.
Has anyone else noticed or experienced this? Any thoughts on where the issue may be?
Old Jul 2, 2024 | 02:14 PM
mhollem's Avatar
mhollem
You probably need to add resistors in series with the LEDs.
Old Jul 2, 2024 | 04:48 PM
LCA078's Avatar
LCA078
Most LEDs use phosphors on top of the actual light emitting diode to generate the light we actually see. Those phosphors tends to glow for a bit once the LED is actually off which can be very noticable at night but not really during the day. Are you referring to that glow -or- are they still emitting a minute or two after being off?
Old Jul 2, 2024 | 05:12 PM
BigBair's Avatar
BigBair
They are on all the time - you can see them during the day, but they’re maybe 5% as bright as they are in reverse. It’s the GTR Ultra bulbs from Headlight Revolution.
Old Aug 5, 2024 | 08:06 PM
BigBair's Avatar
BigBair
I finally reinstalled the factory bulbs and it seems to have corrected the issue.
Old Sep 20, 2024 | 11:20 AM
gespeter's Avatar
gespeter
Yeah, put a fat 6 or 12 ohm 50 watter across the circuit, that'll fix it.
Auto parts stores sell them. In the lighting section. They get pretty hot. Best to screw them to bare metal for heat dissipation, chinesium power resistors are kind of weak. If you can find genuine IRC, Dale, etc, they can take the heat. Just keep them away from the harness. Amazon sells them also.
Two 12s in parallel = 6
Two 6s in series = 12
12 ohm @ 12v = 1a = 12watts
​​​​​​But go for the aluminum ones you can screw down. If you have some Heatsink Compund, like used in computers and electronics, that will make them run even cooler. It aids the transfer from the resistor and the thing it's bolted to. Steel is OK, not as good of a heatinsink as Auminum, but it still really helps.
Bigdaddy77
Nov 3, 2021 06:35 AM
Sean Roth
Apr 17, 2021 11:35 PM
ssande
Jun 22, 2017 10:20 AM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
GrampsHandMeDown
2004 - 2008 F150
Dec 27, 2008 10:49 AM
