6.7 intercooler
Old Jul 2, 2024 | 06:09 AM
Hmcfly626's Avatar
Hmcfly626
I have 2017 f250 6.7 and I have 38000 on it ive been reading that the cold side intercooler have been going out I'm going on a 3500 towing trip soon should I replace this before the trip with a metal one instead of the rubber one I can't look at it now because it's at ford for a extended warranty problem or should i just let ford look at it I guess I don't want this to blow on our trip thanks all
Old Jul 2, 2024 | 07:41 AM
BadDogPSD's Avatar
BadDogPSD
Originally Posted by Hmcfly626
I have 2017 f250 6.7 and I have 38000 on it ive been reading that the cold side intercooler have been going out I'm going on a 3500 towing trip soon should I replace this before the trip with a metal one instead of the rubber one I can't look at it know because it's at ford for a extended warranty problem or should I just let ford look at it I guess I don't want this to blow on our trip thanks all
It's a pretty common failure point on the 2017-2019's, I'd probably replace it if it was my truck. Lot's of good aftermarket options.
Old Jul 2, 2024 | 07:57 AM
WXboy's Avatar
WXboy
Mine is original as far as I can tell at 94k miles and I tow in the heat with the truck. I don't know...
Old Jul 2, 2024 | 08:11 AM
JoeUser's Avatar
JoeUser
If you're worried about the cold side hose blowing out, then just buy a spare hose and keep it in the truck in case it ruptures while on the road. They're not that terribly expensive, nor hard to replace (just two hose clamps).
If you're talking about the intercooler itself, and at your mileage, it should be fine (unless you're having issues with it, then in that case have the dealer replace it under warranty before your trip).
Old Jul 2, 2024 | 08:18 AM
honda250xtitan's Avatar
honda250xtitan
x2 just throw one in the truck for insurance. snag an oem one or SPE sells an OEM style one for cheap too. they also have their fancy one for not cheap
youre at low mileage though, i wouldnt expect any issues. mine went out around 80k
Old Jul 2, 2024 | 08:27 AM
speakerfritz's Avatar
speakerfritz
My list of things to bring on a long road trip would include air flow sensors before intercooler piping.
if the intercooler cold side goes out…you can remove it, clean it, wrap it in duct tape, put it back on until you get a new one.
Hmcfly626's Avatar
Hmcfly626
I was talking about the pipe
Old Jul 2, 2024 | 08:28 AM
speakerfritz
See replies to your other thread with the same title
(Mod note-Merged threads)
Old Jul 2, 2024 | 03:22 PM
nc350's Avatar
nc350
Carry a spare or just replace it with a metal one. There's several good providers out there that make em. S&B and Sinister Diesel were the two that I looked at then I bought one. Unless you see visible damage to the hose, I don't think you need to rush to do it. But they're definitely known to blow at higher mileages.
Old Jul 3, 2024 | 10:33 AM
TX Crawler's Avatar
TX Crawler
This. I "patched" mine with duct tape until my new one showed up. I didn't even know mine had a hole in it until I noticed it one day changing the oil.....
k7lvo
6.7L Power Stroke Diesel
Jan 25, 2017 08:01 PM
Bowhunter2001
2009 - 2014 F150
Jan 25, 2013 05:33 PM
Simmy150
2009 - 2014 F150
Dec 27, 2012 06:42 PM
IATOWMATER
Aug 19, 2009 04:54 PM
