AC injectors
Old Jul 5, 2024 | 10:26 AM
ESwift's Avatar
ESwift
CNCFAB
Originally Posted by cjfarm11
I know your not asking me but I got a good tow in up the mountain last weekend with the now sxr turbo and it is definitely better then the sxe but it’s not the same size either. For me I’m very happy with the change
I am soo temped to try the sxr just to see the difference, but soo not wanting to spend the money lol
Old Jul 5, 2024 | 11:38 AM
brian42's Avatar
brian42
Veteran: Navy
Loved my 160/80's. The truck wasn't faster but was a lot stronger and it felt like I could change the earth's rotational speed with my right foot.
As @Sous said, getting the air in and the exhaust out are the first things you should tackle.
Even with my modified stock turbo I could set off the filter minder with ease. I had to ditch the 6637 for more flow and still had some hazing. I'm pretty sure the stock turbo was the problem and had plans to upgrade to a GTP38R (have to stay OEM - or at least look OEM - in CA to pass smog) but a distracted Jeep Wrangler driver ended my PMS habit.
Old Jul 7, 2024 | 10:34 PM
cjfarm11's Avatar
cjfarm11
Ya if I woulda swapped the sxr for the same size sxe then I coulda been a lot more helpful. The sxr does seem to have a little more whistle noise then the sxe
Old Jul 7, 2024 | 10:52 PM
glovemeister's Avatar
glovemeister
@cjfarm11
What is the part number difference between sxr,and sxe turbo?
Old Jul 7, 2024 | 11:00 PM
cjfarm11's Avatar
cjfarm11
I’ll have to look
Old Jul 16, 2024 | 06:55 PM
Jregezeino's Avatar
Jregezeino
Y’all with previous experience recommend 160/0 over 160/30 or 180/30s? Paired with a 364.5/.91 sxe and good airflow, otherwise stock-ish plus frx and a FPR setup to 67psi.
im still on 247k stock injectors which are doing well, but I’m just planning ahead for the day that they start to give up.
This is a 2001 excursion, with stock SD Michelins and 3.73s, frequently pulling a 8200# TT, sea level to 3k’ but mostly flat here in the SE USA. She does well at the moment, but I’d like to see the turbo come alive a little earlier (1900rpm now) and thus reduce my 3-4th gear transition temps which hang out around 950-1100.
I Realize that with anything more than 160/0 I’ll probably need a new IC as well to help keep the temps in check. Just looking for some reliability advice since I’ve never been in a 7.3 with anything but stock sticks.
Old Jul 16, 2024 | 08:35 PM
Wes444's Avatar
Wes444
364 is too big for your gears and anything below 200s in injector size. When I towed a 5th wheel back in that weight area with stock injectors they were plenty for crossing the Rockies on i70 thru the Eisenhower pass. I'd recommend a 363/84 for stock to 160/x . It supplies plenty of air with my 160/0's, I see mid 30s on boost pulling grades and no EGT issues at all
Honestly if I could do it all over for towing in that weight range, I'd stay with stock injectors, KC SXE turbine, RiffRaff 4+4 and a 4" turbo back. Was plenty with just a 40hp tune. Granted that turbo setup kept my 160s clean @40hp, as well my stock injectors @ 60 & 80hp tunes towing 13k#
Only if your current one has the plastic end tanks and has split, otherwise the turbo map has more to do with it than a new IC will ever do
Replies in red
Old Jul 16, 2024 | 08:50 PM
Jregezeino's Avatar
Jregezeino
Thanks brother, much appreciated. Yes, I do wish I had gone with a 363, my quest was somewhat experimental. That said, a new 363 would ultimately be a more cost effective option than all of the satellite expense associated with new injectors while the originals are still plugging away.
i do have a new adrenaline HPOP on the shelf, was planning to start there plus a new IPR and see how the truck behaves with that. Any concerns with high mileage injectors responding negatively to the increased flow of the new oil pump?
Old Jul 16, 2024 | 09:01 PM
udsuth78's Avatar
udsuth78
If they're going to fail they're going to fail, the health of the high pressure pump won't have a whole lot to do with that. You might notice a little more pep maybe a little crisper throttle response. I may have missed it but is this truck tuned at all? If not then that's where you need to start/
Old Jul 16, 2024 | 09:09 PM
Jregezeino's Avatar
Jregezeino
Yes the truck has a hydra with their tunes which I typically run on the “performance 120” setting. I’ve never been thrilled with the shift points which is what had me contemplating the jelibilt tunes/FFD 1.5 combo in the first place to save a few bucks vs buying his split shot tunes and eventually buying adjustments for the singles.
It’s sounding though like that may be the way to go anyway.
Old Jul 16, 2024 | 09:44 PM
RacinJasonWV's Avatar
RacinJasonWV
There is an important factor left out when describing your turbo. The turbine size is often not mentioned but has a significant impact on when it starts to spool. Most guys end up with the 73mm which in my opinion is too big with anything close to stock injectors. The 68mm turbine will perform better in the area you’re looking for, and for me with stock injectors, it’s never ran out of air up top. I’m running the 363/68/.91 after removing a 364.5/73/.91.
BTW changing the turbo actually made my shift points feel MUCH better. It was always under the turbo with the 73mm requiring extra throttle.
You can also go with the tighter .83 A/R if really after early spooling.
Check out information about turbos here. https://www.ford-trucks.com/forums/1...e-reviews.html
Old Jul 17, 2024 | 09:51 AM
BradyT88's Avatar
BradyT88
I'm a little rusty on this, but won't the .83 cause your exhaust backpressure to get pretty damn high on the top of the RPM range?
Old Jul 17, 2024 | 09:57 AM
  #28
ESwift's Avatar
ESwift
CNCFAB
I run the .83 with 200/30, ebp:boost ratio is just fine all the way across the rpms
Old Jul 17, 2024 | 10:11 AM
  #29
BradyT88's Avatar
BradyT88
I wasn't watching my ebp but on this last trip I kept throwing 2 SES pulling my 10K lb 5th wheel toyhauler on steep passes. High ebp and Low ICP pressure. I'm running stock injectors and stock turbo with the KC Turbine upgrade. Running the 1023 Heavy Tow tune to keep EGTs below 1300 and running about 26 psi of boost with my foot to the floor and going about 55-65 mph depending on the steepness of the grade in 3rd gear with my auto trans.
Old Jul 17, 2024 | 10:47 AM
  #30
ESwift's Avatar
ESwift
CNCFAB
Boost top center
ebp just below it
egt lower left
this was with a leaky up pipe, so def pretty good.
13k up a %12
