What do you think?
Old Jun 29, 2024 | 08:32 AM
ajjw0828's Avatar
ajjw0828
What do you think?
Drive my truck to go get our camper out of storage the other day. Noticed it smokes quite a bit and has an annoying smell in the cab when it warms up. Popped the hood and took a video. Seeing blowby/ smoke out the dipstick and the ccv. Nothing out the cap and it doesn’t blow off the oil fill cap when I flip it. Motor says 306,000, so who know what mileage it has if the odometers roll back at 400,000. Thinking about hitting up local machine shop to see about pricing on rebuilding or buying an already rebuilt long block. Interested in if anyone has rebuilt their motor or purchased a rebuilt long block. Thanks, AJ
File Type: mov
File Type: mov
Old Jun 29, 2024 | 01:35 PM
Hit Man X's Avatar
Hit Man X
I would perform a compression test.
Ace those OBOD quick and get those Riffraff ones. Yours may have split and dusted a cylinder or two.
Old Jul 2, 2024 | 01:37 PM
knottyrope's Avatar
knottyrope
that dont look bad to me, compression test will rule out issues
Old Jul 2, 2024 | 02:58 PM
97-psd's Avatar
97-psd
Check the up pipes for leaks.
Old Jul 2, 2024 | 09:05 PM
ibowl9's Avatar
ibowl9
It shouldn't be smoking from between the CCV vent and valve cover. That pressure should be going into the intake tract.
I'd check the CCV vent on the valve cover for a clog or blockage. There will be pressure from blowby even on a healthy motor. It's going to go somewhere. That somewhere is usually thru the vent into the intake tract. If it is blocked, it's going to seep out anywhere it can.
Old Jul 2, 2024 | 09:17 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Blow by flows out of my ccv housing like that also. I assume it's the o-rings between the housing and valve cover. I do not get any coming out of my valve covers or dipstick though.
Old Jul 2, 2024 | 09:33 PM
ibowl9's Avatar
ibowl9
https://dieselorings.com/products/8-...3l-ccv-o-rings
Probably $10 shipped will have that leak fixed and hopefully cut down on some smell. Riff Raff has them too if that's your flavor.
I think the dipstick leak requires a new dipstick to fix. I'm not aware of the seals/o-rings on the dipstick being serviceable.
bass-n-fire
15
Feb 6, 2018 03:11 PM
redz284u
6.4L Power Stroke Diesel
Sep 28, 2016 07:41 PM
truck7575
Apr 26, 2015 07:14 PM
63' f100
18
Mar 13, 2013 10:54 PM
fordff
Feb 1, 2009 01:53 PM
