truck has been down too long - Ford Truck Enthusiasts Forums
Old 01-20-2018, 09:16 AM
kupiec20's Avatar
kupiec20 kupiec20 is offline
kupiec20 is starting off with a positive reputation.
so the story goes....
driving my truck down the hwy and it started to sputter. Like it wasnt getting fuel. After getting it towed home i opened up the fuel bowl and there wasnt any fuel.
So i replaced the fuel pump. While i had the fuel bowl i rebuilt the FPR and the fuel bowl.
So i went to start it and i was not getting fuel to the bowl at all.
I put a fuel gauge to it and i wasnt getting any preasure at all.
i tried switching tanks and still no fuel flow.
My question is. If there a issue with one of the tanks wouldnt just switching over to the other tank eliminate the issue?
Any other thoughts would help.
thanks
Old 01-20-2018, 09:22 AM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputationhelifixer has a superb reputation
tank selector valve failed and stuck in the center is a possibility.
Old 01-20-2018, 09:34 AM
helifixer's Avatar
remove suction line @ quick disconnect on frame driver side behind front tire, remove fuel caps, blow compressed air in to line (gently like 5 pounds) and have someone listen for bubbles or air flow into tanks, switch tanks and verify both.
also check fuse for tank selector.
Old 01-20-2018, 12:29 PM
Shawn MacAnanny Shawn MacAnanny is offline
Shawn MacAnanny is starting off with a positive reputation.
You could have a pinhole of rust in a fuel line / sender somewhere too (my tank senders are stainless but the rail lines looked mild steel). The fuel pump sucks from the tank, so if there is air getting in anywhere itís going to pull air before fuel. Could be a rubber flex line to quick connect oring too. It can leak air under vacuum but not fuel.
Old 01-20-2018, 12:32 PM
If you really wanted you can cut the rubber or steel line feeding the bowl under the truck frame rail and run a piece of 3/8Ē fuel line from it to a can of diesel and thatíll rule the tanks, senders, and fuel valve out. You can always couple it back together with rubber. Thatís what efuel kits do anyway.
Old 01-20-2018, 04:31 PM
kupiec20's Avatar
Thanks for the replies.
ok i blew air back through the supply line. when i had it on front tank i heard a bubbling sound. when i switched it to the rear i heard a air sound.
fuse checked out good.
Old 01-21-2018, 07:45 AM
Air on the rear sounds like there isnít a shower head in the pick up or itís not below the fuel
level. Blowing air wonít find a pinhole leak though.
Old 01-22-2018, 01:56 PM
kupiec20's Avatar
Quote:
Ok
Do i need to use a return line also?
Also. Prob a stupid question but...
If i fill the fuel bowl with fuel.
Will i be able to get the engine started?
Old 01-22-2018, 07:11 PM
You dont need a return line to make it run. It'll suck the fuel can out faster and just put it back in the tank but if you have a fuel return line leaking itll be an external leak and you'll see it, and it will not affect your trucks ability to run.
I do not think filling the fuel bowl up will get your truck started and running, it'll help, but its going to take a minute or two of running just to get the air worked out of those heads and injectors.
Old 01-23-2018, 05:59 PM
mcali2's Avatar
mcali2 mcali2 is offline
mcali2 is gaining momentum as a positive member of FTE.mcali2 is gaining momentum as a positive member of FTE.
I sure am glad I went e fuel. soap up the line and blow are in them again. see of you get bubbles. I can see a minor leak keeping it from getting enough fuel to get it running. I would fill up the fuel filter area and try starting it. Maybe the RPS will get things going.
Old 01-25-2018, 04:01 AM
kupiec20's Avatar
ok
so I hooked up the supply line to a 5 gallon jug of diesel.
I also filled the fuel bowl. tried to start it and got nothing. Fuel pressure gauge off the FPR wasn't moving.
So when is fuel pressure measured? at what point.
When I re-oringed the FPR did I mess it up? im out of ideas...
Old 01-25-2018, 06:15 AM
I'm sure it's possible it got messed up. Maybe your fuel pump is broken? And the fuel bowl leaked out through the broken pump into the crank case? I'm not sure if that can happen but thats all thats left if you haven't replaced that pump. Unless there is a crack somewhere the supply line or rubber line leading to the fuel pump causing it to draw air.
97 7.3 crank no start please help Iron_born 1994.5 - 1997 7.3L Power Stroke Diesel 11 12-24-2017 11:24 AM
The Chronicles of Fuel Bowl Leaks CousinCarl 1999 - 2003 7.3L Power Stroke Diesel 7 12-18-2017 05:01 PM
Fuel can not getting fuel Raymond Hines 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-21-2017 02:42 PM
no start/no white smoke 967.3zf5 1994.5 - 1997 7.3L Power Stroke Diesel 9 06-19-2016 05:14 PM
Fuel Bowl Drain Raleigh234 1994.5 - 1997 7.3L Power Stroke Diesel 12 05-26-2016 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
