Sponsored by: Real Truck
2015 F250 ABS Control Module
Old Jul 1, 2024 | 08:56 AM
PatrickStapler's Avatar
PatrickStapler
My truck appears to have a small leak at whatever is located directly above the driver side front coil spring perch. It appears that all of the brake lines run in that direction so I assume it is the ABS controller. The brakes and ABS both function good. Is it possibly just a bad connection or do these parts generally fail in this manner?
Looking at FordPartsGiant this morning, there are two units listed, EC3Z-2C215-A Abs Control Valve, and Ford EC3Z-2C219-B Control Module. These parts appear very similar graphically, but have different part numbers, description, and price. Does the truck use both or one or the other?
Old Jul 1, 2024 | 09:53 AM
PatrickStapler
For reference, here are the two parts...
Old Jul 1, 2024 | 12:41 PM
PatrickStapler
So this is the part on my truck. It appears the connections are on top...which are under the coolant reservoir and possibly the battery tray. Anyone have any photos or video for removing these items or is it pretty straight forward?
cjensen68
Crossovers
Mar 14, 2022 10:40 PM
7.5GasHog
32
Mar 5, 2018 03:45 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
