Mpg
Old Jun 30, 2024 | 04:12 PM
Hmcfly626's Avatar
Hmcfly626
Mpg
I trying to evaluate a Dr performance modules for mpg I have a 2017 f250 6.7 rwd I'm getting about 15 city and 20 highway I was just what other people are getting stock thanks
Old Jun 30, 2024 | 04:23 PM
TestPilot57's Avatar
TestPilot57
Take a look at Fuelly.com.
According to https://www.fuelly.com/car/ford/f-25...=&submodel_id= 15MPG is right in the middle for a 6.7 F250, with over 44 million miles analyzed.
Old Jul 2, 2024 | 08:39 AM
Hmcfly626's Avatar
Hmcfly626
Ok this dr performance modules doesn't seem to be helping my mpg any so what kind of tunner do you recommend for towing and mpg I don't want want to ruin my warranty I have till February on it thanks all
Old Jul 2, 2024 | 09:12 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Any tuning, actual tuning, not just an intercept device like that Dr thing, will void the powertrain warranty.
Your truck already has more than enough towing power, as to fuel economy, easiest and cheapest solution is to SLOW DOWN.
Old Jul 2, 2024 | 09:44 AM
4wd6.7L's Avatar
4wd6.7L
Yeah, it's all in how you manage the go pedal. Gotta drive like a grandma and not exceed about 70 MPH on the highway to get max MPG. Your numbers look about right for a stock 17-19 2wd SD. Mine are a little lower being a 4wd.
Old Jul 2, 2024 | 10:54 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I would amend that MPH number to 65 or less for max towing MPG, and use the cruise as much as possible, consistency is key, cruise is consistent, your foot isn't!
Old Jul 2, 2024 | 03:31 PM
nc350's Avatar
nc350
Sounds like you're right where you're supposed to be. Maybe a delete would help. But then you be got a whole different set of considerations to decide on if thats something you want to mess with.
Old Jul 2, 2024 | 03:39 PM
Hmcfly626's Avatar
Hmcfly626
yes but a delete in California I would assume is a big no no
Old Jul 2, 2024 | 03:58 PM
twobelugas's Avatar
twobelugas
Any CARB states for that matter.
There are a few counties left with no smog requirements but it's unlikely people living there are buying the new diesels. If your address requires smog then yeah, everything has to be either stock, or have a CARB sticker.
Old Jul 3, 2024 | 04:14 AM
nc350's Avatar
nc350
Then add in the potential challenges or issues selling a deleted truck as well!
Old Jul 16, 2024 | 07:40 PM
Hmcfly626's Avatar
Hmcfly626
well I install a new k n air filter and a sb intercooler pipe and a fass fuel filter system I'm on my 3500mile trip now we are keeping the speed at 65 and now im average 10-11 mpg thats much better that the 8 i used to get im also adding archoil to every fill
Up pulling a 9500 trailer wow im happy
Old Jul 16, 2024 | 08:22 PM
nc350's Avatar
nc350
Were you keeping it at 65 before?
Old Jul 16, 2024 | 08:35 PM
johndeaux22's Avatar
johndeaux22
It’s hard to compare without knowing gear ratios…
My ‘24 F350 DRW S/C 4x4 6.7 with 4:10’s averages about 14.5 without a trailer. The trailer most commonly behind it runs around 23,500 loaded and 14k unloaded, I average around 6 loaded, and 7.5 unloaded.
2017 F350 DRW C/C 4x4 6.7 with 4:10’s is typically about .5 MPG better with the same trailer. Both trucks have a trailer behind them 90%+ of the time.
The ‘24 is EXTREMELY thirsty for DEF with the trailer behind it - around 1 gallon/200 miles, the ‘17 averages about 1 gallon/1000 miles over 225k miles.
Old Jul 17, 2024 | 06:04 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Yeah the guys who are towing at 70+ either aren't burning their own cash or have deep pockets. Best towing MPG is at 65 or below, as the drag due to the trailer increases exponentially because of the larger frontal surface area. Slowing down is about the only way to really improve mileage (this also applies when NOT towing but it's not as drastic).
Old Jul 17, 2024 | 06:25 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Cut out a couple fast food dinners a month and you won't have to worry about 1mpg here or there.
