Fuel tank size
Old Jul 13, 2024 | 12:05 PM
  #31
nc350's Avatar
nc350
Originally Posted by gSwift
You can still use the high flow truck stop pump nozzles, you just can't use it on the fastest setting. I use the 1st and 2nd click with no issues at all.
I'm lucky to even get to the first click.
Old Jul 13, 2024 | 12:08 PM
  #32
nc350's Avatar
nc350
The short bed was 6.75f I thought...
The 60gal tank is the replacement for the OE tank on a shorted.
If you have someone do the install for you, do them a favor and show up with a pretty empty tank. Bring a 5gal can of fresh diesel when you pick it up. That way you reduce the risk of having that fuel pump run dry.
Old Jul 13, 2024 | 03:45 PM
  #33
Joe T's Avatar
Joe T
Can you adjust the 2017 tank size in Forscan. My mpg lie-o-meter and distance to empty definitely both need adjustment. Only concerned with the DTE as it gets closer to empty.
Originally Posted by wudwork
I replaced my stock 34? gallon tank with 55 gallon Titan tank. I have 2019 F350 short bed supercrew cab. I cannot recall the foam issue ever causing a delay in filling up. My local Ford dealer is an authorized Titan dealer so it was easy to get the swap.done. NOTE: The new titan tank becomes the lowest point on bottom; they had to remove the shield that came with FX4 package. I would do same upgrade if I purchased a short bed again, very well worth it. Also the biggest benefit is I never drag my camper thru a gas pump anymore; I always land at new campground with at least a third of tank so I can drive around and get lowest fuel price.
Thought about it but I do not tow long distances. I recently bought an SUV to daily too and may set my truck up for more off road stuff and the stock skid plate is tough as nails (its been extremely tested and replaced before).
Old Jul 13, 2024 | 03:52 PM
  #34
wudwork's Avatar
wudwork
I paid $2200 for tank, install and disposal of old tank and shield. One thing; they insisted I drove in with 1 drop of fuel in old tank. No-one wants to lower a tank full of fuel.
Originally Posted by nc350
Was that tank and install or just install.
I had a supposedly reputable place by me quote me that for just the install. It was crazy. Obviously didn't go with that guy and never will for any other work lol
Old Jul 13, 2024 | 03:57 PM
  #35
wudwork's Avatar
wudwork
Yes, its a simple Forscan update but it ends up working like the original tank fuel gauge in that 1/2 tank on dash does NOT equal half tank of fuel.
Old Jul 13, 2024 | 04:00 PM
  #36
Joe T's Avatar
Joe T
But can you trick it? Say it has a 40 gallon tank?
My stock tank is 36. I believe it has around 7-8 gallons left a 0 DTE.
Old Jul 13, 2024 | 04:11 PM
  #37
nc350's Avatar
nc350
What do you mean?
Old Jul 13, 2024 | 07:57 PM
  #38
2021F350's Avatar
2021F350
Originally Posted by Hmcfly626
well im guess im all messed up with ford specs i thoung i had a long bed but when I entered my Vin on kbb it said I had a short bed so I measured it and it's only 6.34 so I guess I have a short bed that's why I don't have a 48gallons tank and only 34 gallon humm
and there you be... What was once called a regular/standard bed (8' bed) is now called a long box, what was once called a short box (6.34" box) is now called a regular box/standard box, and what is now called a short box I would call, a useless box... JMO as I see it...
Old Jul 14, 2024 | 07:03 AM
  #39
nc350's Avatar
nc350
Did Ford increase the size of the short bed box at some point in the recent past? 6.34ft isn't an option, not has it been for a few years. It's 6.75ft.
Old Jul 14, 2024 | 04:39 PM
  #40
wudwork's Avatar
wudwork
The fuel gauge, in every car I have owned in 40+ years, would say 1/2 tank yet when I fill up it was always more than 1/2. The fuel measurement systems seem to be much more accurate when above half tank. My 55 tank has same issue.
What do you mean?
r-kid
6.7L Power Stroke Diesel
16
Nov 5, 2018 03:07 PM
CabelasSD
Jan 17, 2012 07:28 PM
fordmarshall111
May 11, 2010 02:03 PM
bvieages
Jan 14, 2010 11:58 AM
abcdefg
Jul 2, 2000 02:29 PM
