Temp gauge help.
Old Jun 23, 2024 | 09:55 AM
NM76F150's Avatar
NM76F150
Temp gauge help.
48 F1 6 cylinder.
Need some help on the temperature gauge. It doesn’t register engine temperature.
Gauge works as it should. Full hot with key off, full cold with key on. There is continuity between the gauge and the sender. The sender has been replaced. Did I get a faulty sender? Where do I look next?
Thanks in advance.
Old Jun 23, 2024 | 10:16 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Can you share the part number your ordered? Does it have one or two terminals?
The shop manual outlines how to test the gauge and sender. Essentially, you test the gauge; if the gauge is good, the sender is considered faulty and replaced. You can also use two D cells in series for full gauge swing and one D cell for halfway.
Old Jun 23, 2024 | 10:42 AM
NM76F150's Avatar
NM76F150
Not sure of the part number. Single terminal. Got it from Dennis Carpenter. I’m pretty sure the gauge is good but I’ll try the D cell test thanks. Seems odd that old sender and the new aren’t working.
fordf348
Apr 24, 2019 06:08 AM
mod22
Jul 17, 2017 03:46 PM
49fordv8f4
Jan 25, 2016 10:05 PM
cosmaar1
Jul 15, 2013 10:16 PM
tlb
Sep 8, 2004 05:24 PM
