ac issue
Old Jun 21, 2024 | 03:04 PM
jaymiller's Avatar
jaymiller
5th Gear
ac issue
I have an 06 F250 with the 6.0, I have replaced the ac compressor, condenser, accumulator, and actuator, I am still not getting very cold or strong ac blow and it fluctuates to heat when I am slowing down, what else could be the issue? it also has a full charge and is not leaking.
Old Jun 21, 2024 | 04:50 PM
joe blow's Avatar
joe blow
There is another thread going on with similar symptoms. Sounds like you've changed damn near everything.
Did you replace the orifice tube filter when you replaced the receiver/dryer and was it put in correctly? It goes in one specific way but can be put in backwards.
***what is the "actuator" you mentioned?
Old Jun 21, 2024 | 06:05 PM
jaymiller's Avatar
jaymiller
5th Gear
yes i replaced the orifice tube and put it in the same way that the original came out, the actuator is for the blend door.
Old Jun 21, 2024 | 06:09 PM
joe blow's Avatar
joe blow
Have you checked your vacuum system integrity (leaks) and the vacuum actuated heater core valve to be fully off and working properly?
If it is not closing you'll have hot coolant through the system sacrificing your cold air.
Old Jun 21, 2024 | 07:15 PM
jaymiller's Avatar
jaymiller
5th Gear
no i have not yet
Old Jun 21, 2024 | 07:36 PM
jaymiller's Avatar
jaymiller
5th Gear
just checked vacuum, no leaks, there was a hose ran between the heater core arm and the actual heater core so now i have cold air but not strong
Old Jun 21, 2024 | 10:21 PM
JJF20's Avatar
JJF20
Doubt it would fluctuate as described, but is the heat diverter valve plugged in, and working? I’ve had issues in the past with semi-cool ac, but never quite gets cold. It can fluctuate a little iirc.
Old Jun 22, 2024 | 09:47 AM
jaymiller's Avatar
jaymiller
5th Gear
it was the heater core arm that closes off the heater core, it was obstructed by a hose, now i have cold ac, replaced the blower motor now too and it is blowing a bit harder but still not real hard.
Terry SD
6.4L Power Stroke Diesel
Jul 11, 2014 12:34 PM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
Falcon731
May 4, 2009 03:50 PM
galaxie223
Jul 31, 2003 09:20 PM
Chris_ce
1983 - 2012 Ranger & B-Series
Jul 6, 2003 08:44 AM
