Codes
Old Jun 19, 2024 | 08:26 PM
badtruble's Avatar
badtruble
1st Gear
Codes
2001 Ford Expedition drove fine parked it and next startup its in I assume Limp mode idles fine put in gear and give a little gas and engine bogs down and dont move. I can drop it into !st and kinda feather the gas and it will move. I got codes for days.
P0740, P0743, P0755, P0758, 1747, P1754, P1760, P0443, P1451, P0135, P0141, P0155, P0161, P1127, P1408, P1780, There is a few B codes also B-1322, 1482, 1371, 1818, 1814, 1313, 1302, 1450, right before in went into nogo mode the window fuse kept blowing but now know the switch is bad if anyone give me a place to start I would really appreciate it from doing a little rsearch I'am thinking maybe Trans Solenoid any input would help please
Oh and the emission codes at least O2 sensors been bad and it still was driveable
Old Jun 20, 2024 | 09:32 AM
alloro's Avatar
alloro
That's a lot of codes for any one part to have failed. I would start by visually inspecting the wiring under the hood and under the truck for any damage. Next, I would remove the two upstream O2 sensors, start the truck (it will be loud) and then see if it will drive. If it does, the exhaust is plugged.
JaxJim
Apr 28, 2021 01:39 PM
iateatoad
13
Dec 8, 2012 10:35 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
