vacuum advance question
Old Jun 19, 2024 | 09:40 AM
Jeff Wecker's Avatar
Jeff Wecker
Had to replace the vacuum advance on my 1973 F100, due to the diaphragm being totally disintegrated. I have the hose, coming out off the front of new one going to the port on the side of the carb, as seen in the photo.. But where does the hose nipple coming out of the top of the advance go, to the manifold vacuum tree at the rear of the intake? Or can I cap that fitting off?
Old Jun 19, 2024 | 10:24 AM
Pickupmanx2's Avatar
Pickupmanx2
I believe you can cap the top one off, I'm drawing a blank as to what you call it, but IIRC it's for retarding the timing when decelerating... ?
Old Jun 19, 2024 | 08:33 PM
440 sixpack's Avatar
440 sixpack
Yes. unless all your equipment is in working order you're best off to just run the advance hose to ported and forget it. I ditched all that garbage when they were new and I never did understand it, or wanted to.
I just put a can that was correct for a '76 on my '79's. .
Old Jun 20, 2024 | 12:39 PM
Jeff Wecker
The one I put on is the only one that was listed for breaker points for 1973. I've got the front hose to the ported fitting on the carb, and that other one capped, so should be good to go
christito
Sep 4, 2023 11:44 PM
Aggietrucks
Oct 3, 2022 06:08 PM
hillcountryflt
May 2, 2014 09:02 AM
Deviousfred
Jul 14, 2011 12:10 PM
70charger
Feb 26, 2004 11:05 AM
