6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
P2291 code
Old Jun 28, 2024 | 02:45 PM
DieselDenny's Avatar
DieselDenny
The reason I asked about the filter and cap on the secondary (fuel bowl filter and cap) is important.
You said " I have no reason to believe it's not original". Never go with your beliefs on a second owner truck or any other vehicle.
Aftermarket caps have been floating around for many years. The problems that go with them have too.
If the cap is slightly taller than OEM, and you use an OEM motorcraft filter, it won't compress the plunger in the fuel bowl to the correct level. Meaning that the fuel will vacate the bowl via gravity and introduce no starts or hard starts, air in system.
For what your going thru and the cost of an OEM cap. Just get one so you can sleep.
Every month I drain my primary in a glass jar and let it settle overnight for inspection of water/debris. I cycle the key for 20 seconds 8-10 times and have never had a problem with air.
Just sayin
Denny
Old Jul 1, 2024 | 05:56 AM
TravisP2001's Avatar
TravisP2001
4wd Low
I had a bad fuel filter oring and or fuel filter. And yes they were motocraft. I must have gotten a dud. I went into town yesterday morning got another set of filters and changed them. One last ditch effort before calling in someone with more expertise than me. I only changed the upper filter and it's oring. I figured I would try just that one before doing the harder one under the truck. After bleeding the fuel for 10 minutes using Forscan, the truck cranked right up and has not missed a beat.
Old Jul 1, 2024 | 01:59 PM
DieselDenny
Attaboy!
Denny
Old Jul 2, 2024 | 09:25 AM
Rudiak's Avatar
Rudiak
Happened to me years ago. Rogue filter. It happens.
yahtzee00
Nov 20, 2023 11:29 AM
Notplayn
Jan 10, 2014 08:12 PM
Mcrafty1
Dec 15, 2013 03:27 AM
dirtduck48
Jun 30, 2012 12:05 PM
99EdeBauer
Jul 31, 2008 07:06 PM
