1996 E4OD into 1992
Old Jun 17, 2024 | 09:15 PM
Canadian_f250's Avatar
Canadian_f250
5th Gear
1996 E4OD into 1992
Hello all!
so I’m fairly new to the IDI world and I’m trying to learn fairly quick. So bare with me please.
this should be fairly flat out, but I have a 1992 f250 7.3idi with the amazing e4od. Recently the tranny let go and the only tranny I could find close to me was out of a 1996 f350. Would they be the same? What would I have to do to make it work?
Old Jun 18, 2024 | 10:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
DId the one from a 1996 come from a diesel? If not, then it won't bolt in. Also, if your truck is a 4x2 the new trans has to be from a 4x2. If it is a 4x4 the new trans has to be from a 4x4.
If it did come from a diesel, I think you'll need to replace the torque converter because if I remember correctly your truck has a four stud converter and the 1996 will have a six stud converter. You don't want to use the converter out of the failed transmission because it will bring debris with it and cause the new transmission to fail.
Also, the 1996 solenoid body isn't compatible with the 1992 computer. You need a solenoid body for a 1992.
Old Jun 18, 2024 | 04:10 PM
Canadian_f250
5th Gear
thanks for the heads up! I greatly appreciate that.
it is coming from a powerstroke yes. I do have the solenoid block already out?
They are both 4x4
Old Jun 20, 2024 | 09:44 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...smissions.html
good info on transmissions
WutBrakes351w
Mar 22, 2011 04:55 PM
crawdad
Dec 17, 2007 09:38 AM
chiaml
Oct 1, 2007 06:16 PM
Harley12
Oct 28, 2006 08:12 AM
