1994 E150 Power Distribution Box Problem
Old Jun 16, 2024 | 05:37 PM
willem_at_work's Avatar
willem_at_work
Hi,
I have a problem with my fuse box in the engine compartment. For the ABS Relay the middle pin in t he fuse box is missing, i think it somehow broke off on the inside? in the attached image i have stuck a probe in the described hole. From what i understand it should have 12V there, but the meter reads nothing and it looks like there is no connector in the hole.
My question is: Is it possible to take the Fuse box apart and see whats going on under there? it looks like the red/white plastic parts can come off, but i'm sure ill break something if i just start prying and pulling.
regards. Willem
Old Jun 16, 2024 | 10:10 PM
Don Ridley's Avatar
Don Ridley
The center pin on Bosch-style relays is the Normally Closed contact, labeled 87a. Depending on the configuration of the ABS system you may not need this contact and this could be the reason there is not a socket in the fuse box.
Old Jun 18, 2024 | 09:20 AM
willem_at_work
ok, thank you i managed to figure out the problem: the relay did't get ground from the fusebox, so i made a temporary solution with an extra wire - for now that fixed the problem of no power to the abs
on another note though, i was wondering if it's possible to open the fuse box and see what's under the relays and fuses? it looks like it should be possible - right?
Old Jun 18, 2024 | 10:05 AM
Don Ridley's Avatar
Don Ridley
Yes, you can access the back of the fuse box.
Old Jun 18, 2024 | 10:58 AM
willem_at_work
what do i have to snap off to do that?
Old Jun 18, 2024 | 07:28 PM
Don Ridley's Avatar
Don Ridley
I don't know the details for a '94 but my '97 snaps together. You should be able to separate the top half and see where all the wires insert from the back.
Old Jun 18, 2024 | 07:32 PM
tabijan's Avatar
tabijan
Can you take it apart from above or do you have to remove the box then take it apart from below?
Sixto
07 E350 5.4 198K miles
Old Jun 19, 2024 | 05:10 AM
manicmechanic007's Avatar
manicmechanic007
They do come all apart
Pretty damn hard
Almost impossible to remove from the truck for service
Diesel4Lyfe
Jun 27, 2022 03:44 PM
BCM
Mar 31, 2022 05:09 PM
94yj
Aug 10, 2021 10:05 PM
FordTruckfan89
Feb 16, 2015 12:35 PM
nightowl_52
Apr 10, 2007 12:03 PM
